power window problems
Old Dec 10, 2004 | 10:37 AM
eds96ragtop's Avatar
96 convertible windows rattle back and forthe side to side and all have tried to adjust but im wondering how much can you adjust and when do you get to the point of saying f it and buy the new regulators and the little muffy pad deals???
Ed
Old Jan 12, 2005 | 01:00 PM
98silverz28's Avatar
Re: power window problems
Um i have no clue either, i am having problems with my driver side window... when i drop press to role it down (especially in the heat) its rubbing on something and makes a loud racket, it vibrates all the way down, and only on the driver side.... any ideas anyone?!
-98 z28
Old Jan 12, 2005 | 03:37 PM
TraceZ's Avatar
I've noticed that our windows are mostly prone to rattling when they are not down all the way, or up all the way.
When down completely, there is a big rubber bumper in the bottom front of the door that the window rests against hard. It prevents it from rattling when down all the way, but only newer cars got this bumper. I recently installed a 2002 door and noticed it was different than my 1994 door in that matter. If your car is older and not equiped with that bumper, it might help to buy one at the dealer and modify it to work in your door. (cut and glue)
At the top of the door, there are two adjustable brackets padded with felt. They can wear out and become loose.
And finally, the outside window moulding at the top edge of the door has bumpers built into it. On older models they were prone to failure because the bumpers were small and the limited surface area caused them to wear out quickly. The newer model mouldings had a full-length bumper that works much better.
I would recommend replacing the outside door mouldings, and the 2 padded brackets. Also get a couple of those big rubber bumpers that fit in the bottom of the door and mount them twards the front bottom where the window approaches the bottom of the door. I have pictures if you need them.
Old Jan 12, 2005 | 03:42 PM
TraceZ's Avatar
-98 z28
Check out Shoebox's website HERE for a video of the window regulators movement. Then take your door panel off and inspect/lubricate all the tracks.
DirtyDaveW
Dec 1, 2016 05:37 PM
dale3in98
Feb 14, 2015 12:18 PM
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
MilkyClr69
Jul 29, 2002 10:01 AM
