Tranny swap
Old Dec 7, 2004 | 03:49 PM
97LT1Z's Avatar
Tranny swap
how hard would it be to drop a blown 4L60E and replace it with another 4L60E? Should I just have a shop do it or try to save some money and do it myself? and would it be easy enough to install a TC while I was doing the swap?
Old Dec 7, 2004 | 06:27 PM
Jay-Roll's Avatar
Re: Tranny swap
It's actually quite easy. The biggest issue I had was removing the 2 stubborn tranny lines on the passenger side. That's mainly because I don't own line wrenches though. Make sure if your doing it at home you have the car up as high as possible. Also make sure you have some good long extensions and a breaker bar wouldn't hurt. This would be a perfect time for a TC install as well. You need to remove the converter with the tranny anyway for a couple reasons. One, you'll probably never get the tranny to come back far enough to come off the TC with the TC still bolted to the flywheel. There's just not enough room. So you'll need to unbolt it and bring it off with the tranny. It's easy, just 3 bolts. Two, you will definately NOT want to reuse the TC that's currently in the car if the tranny is blown. The last thing you want is any little metal particles, or anything else for that matter running through the newly replaced tranny and trashing it as well.
Here is a website that outlines a TC install. He gives great information.
Cam's maro
Aug 11, 2015 07:45 AM
Collinjacobfowl
Jul 30, 2015 09:35 PM
wesley81
Jul 27, 2015 11:31 AM
Boss002
Jul 24, 2015 10:47 AM
