Drive vs OverDrive
Old Aug 31, 2004 | 07:46 PM
Need4Camaro's Avatar
Drive vs OverDrive
Is there any difference in the way the car shifts between the two besides the fact OverDrive opens up 4th gear in all models of Camaro's? (yes this means 3.4's and 3.8's too...)
Does the (3) on the Firebird basicly stand for Drive like on the Camaro? If not, whats the difference between OverDrive and 3?
Old Aug 31, 2004 | 09:38 PM
Re: Drive vs OverDrive
All I can refer to is what I have seen from 1995 LT1 programming. There is very little difference between the manually shifting shift tables and the normal shift tables (when in OD). There are differences are at throttle angles of 31.3% and less, so there is no WOT upshifting shifting difference. Though, it will let you downshift out of OD to 3rd at a slightly lower speed than if you let it kick down by itself.
D=3rd gear
Old Aug 31, 2004 | 10:33 PM
Capn Pete's Avatar
3rd gear in a Pontiac is still the same as "D"rive in a Chevy......D = 3rd gear.
"D"rive in a Pontiac = 4th gear or Over-Drive (D) in a Chevy.
They're all the same 4-speed 4L60E tranny, it's just a different way of labeling each gear.
Old Aug 31, 2004 | 10:44 PM
MarkyMark's Avatar
Ive tested both drive and over drive at the track and I havent noticed any difference in my et's.
jb4xx
Feb 2, 2015 10:00 PM
Snoman73
Nov 17, 2014 07:22 PM
Caps94ZODG
25
Oct 2, 2003 06:30 AM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
Caps94ZODG
Sep 7, 2002 10:09 PM
