Target "Boosted" Compression
Old Aug 12, 2004 | 04:19 PM
PsstTA's Avatar
Using this boosted compression calculator ( http://www.rbracing-rsr.com/compression.htm ) my boosted compression is 19.31:1 and without altitude correction its 19.41:1. Is this to high? What is a target compression to aim for when going with FI? I really want the motor to last, so any info is appreciated, thanks.
Old Aug 12, 2004 | 04:22 PM
rskrause's Avatar
Moderator
Re: Target "Boosted" Compression
The calculator is useless because it uses static CR.
Rich
Old Aug 12, 2004 | 04:40 PM
PsstTA's Avatar
Then what is the correct way to figure your boosted compression? Sorry about this, im a noobie to FI
Old Aug 12, 2004 | 05:08 PM
rskrause's Avatar
Moderator
Well, you could substitute DCR for SCR in the calculator, but I am still not exactly what the result would mean.
Rich
Old Aug 12, 2004 | 05:10 PM
Mindgame's Avatar
Use this calculator. Based on DCR and accounting for atmospheric conditions (natural and unnatural ).
-Mindgame
Old Aug 12, 2004 | 05:14 PM
PsstTA's Avatar
The reason I am doing this is because I am building a FI 383 over the winter. I wanted to drop the compression down to around 8:1 or so and was told that it wasnt needed. I want to run at LEAST 17#s of boost with room to run more if I desired. I was told that 9:1 was plenty low enough for 17 pounds with room to spare. Any inputs on this?
Old Aug 12, 2004 | 07:19 PM
rskrause's Avatar
Moderator
If you plan to run pump unleaded, 9:1 would be too high unless you have a huge cam with a very late intake closing point.
Rich
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
TitoPR221
May 26, 2015 12:20 AM
