nitrous on turboed engine
Old Aug 9, 2004 | 02:36 PM
DCam's Avatar
hi,
I am building a 383 Lt4 stroker for my 95 camaro and i have a few questions. I am building it with callies dragonslayer crank,eagle h-beam rods with upgraded bolt kit, and JE turbo pistons, and a custom cam made for a turbo with small duration and large lobe seperation. What i was wondering is if it is ok for me to put nitrous on the motor for a while (about a 150 shot) until i save up for the big turbo. I just want a little added boost until i get my turbo. Oh yeah forgot to mention the heads, they are AFR 210cc with 76cc chamber. Any info that would be of any help would be greatly appreciated.
-Dcam
95 Camaro Z28 with 383 turbo in the works
Old Aug 9, 2004 | 05:26 PM
rskrause's Avatar
Moderator
Re: nitrous on turboed engine
Sure, there is no problem with it at all. In fact, N2O AND a turbo are a great combo in that as soon as you hit the N2O the exhaust volume dramatically increases and the tubine spools. IOW, bye-bye to turbo lag.
Rich
Old Aug 9, 2004 | 06:02 PM
5.0THIS's Avatar
so if I understand corectly, you just want to run nitrous until you get the turbo.. or do you want to run nitrous with the turbo as well? I'd say a 150 shot on your motor with no boost is fine.. and then once you get boost a 50-75 shot might help with lag, as rich said above
Old Aug 9, 2004 | 07:19 PM
texlurch's Avatar
As I read it, you want to run the spray until you get the turbo. Only worry I would have is the turbo specific cam, if it has less ex duration you might have a little reversion problem on spray..
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
cmdeshon
Dec 12, 2014 10:51 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
