Vig3200 is in
Old May 12, 2004 | 11:06 AM
Robert95z's Avatar
Vig3200 is in
Well its finally in..
From a dead stop it pulls hard and burns down my street tires, from a roll it doesnt feel like its pulling at all
One thing that is giving me a headache is my exhaust! the 3200 cruises at around 2500rpm and my borla is just driving me nuts. Its so loud when i get out of my car I have a headache everytime... I might switch to stock..
I wish i would have went smaller (2800) I'll try hitting up the track this weekend, but the weather has been ****ty
Old May 12, 2004 | 11:09 AM
Bersaglieri's Avatar
Enjoy man, let us know how it runs. And update the sig.
-Dustin-
Old May 12, 2004 | 10:08 PM
"White Knight"'s Avatar
Is it a lock-up? I think it's the 3.73's that are making it run at 2500rpm I'm thinking 3500 stall Good luck--just takes some getting use to from what i hear. What do you mean it doesn't pull from a roll?? it should Anyone else have that prob? of course it won't be as hard but..........
Old May 15, 2004 | 08:35 AM
94DROPTOPZ28's Avatar
I love my 3200 Vigilante converter, it does boil my street tires from a stop but from a 35 or 40 mph roll it definately throws you back in the seat...
Old May 15, 2004 | 08:44 AM
hawk232's Avatar
something is wrong if its not throwing you back from a roll, and as far as the rpm thing, if it is a lock up stall then that is the gears causing it to be at that rpm, makes no difference whether you have a stall or not once it locks up. btw give it at least several weeks of driving before you go back to stock, you will probably end up falling in love with it
Old May 15, 2004 | 11:37 AM
Robert95z's Avatar
Track times are here.... Weather wasnt all that bad either
Best Time:
60' ... 1.818
330 ... 5.387
1/8 ... 8.414
MPH ... 80.90
1000 ... 11.066
1/4 ... 13.306
MPH ... 100.46
Times looked like this all night... Times got worse and worse as I dropped pressure in the ET Streets. I think the et streets are bogging me a little, but this time was with like 20psi and it spun a little too which gave me best time all night. But because it spun i started dropping pressure...
I really dont know why i didnt gain ET and lost about 4mph
-Robert
Old May 15, 2004 | 11:50 AM
Best Time:
60' ... 1.818
330 ... 5.387
1/8 ... 8.414
MPH ... 80.90
1000 ... 11.066
1/4 ... 13.306
MPH ... 100.46
-Robert
Were you running a 26" or 28" ET Street tire? The taller tire might make you loose a couple of MPH. I have run my ET Streets with 12lbs of air at the track (hooked really good) & 30lbs on the street....
Old May 15, 2004 | 12:50 PM
Robert95z's Avatar
they were 26"
Old May 15, 2004 | 01:29 PM
Did you install the torque converter yet?
I picked up almost 3/4's of a second with my converter...
Old May 15, 2004 | 04:33 PM
steve40's Avatar
are you having shifting problems? i had to get programming to fix that since i converted to obdi
94droptopz28, what gears do you have?
Old May 15, 2004 | 06:16 PM
Actually this is in my 97 T/A so I have OBD2 so I don't have the high stall problem, but since I spray the car I'm using a very conservative 3:42 gear with my 3200 converter....
Old May 15, 2004 | 08:00 PM
Robert95z's Avatar
converter is installed, thats why my times are so ****ty...
Yes, the car is programmed for the converter, it shifts fine.
Old May 15, 2004 | 09:03 PM
Wow that's very suprising everybody that I know that installed a converter picked up time anywere between a half and 3/4's of a second...
Old May 15, 2004 | 11:48 PM
steve40's Avatar
well i went from a 13.20 at 104 to a 13.40 at 100. our cars sound similar, i have as&m headers, corsa cat back, obd1 conversion, pcmforless tuning, 3.73's, vig 3200 and a built tranny
i ran the 13.20 on bfg drag radials and the 13.40 on et streets, same tire size. but i did have the shift problems and had to lift to shift. i read somewhere on the board that slightly overfilling the tranny fluid can help, i did that and got a new program from brian. the car does feel different now, i'm just waiting for my drag radials to come in (borrowed the et streets) and have to head out again.
Wildwill2855
10
Jan 26, 2007 07:34 PM
steve40
Oct 16, 2006 04:43 PM
steve40
Oct 24, 2005 05:44 PM
CODE4LS1
Parts Wanted
Oct 5, 2005 11:38 PM
blksunshine
Aug 26, 2004 10:16 PM
