trans not shifting
Old Mar 19, 2004 | 02:17 PM
z28s's Avatar
trans not shifting
i just finished installing my transmission, i had it rebuilt, and had the guy install a transgo jr-700 shift kit. took her for a drive and found out that its not shifting, the fluid is full, does the kickdown cable have any affect on up-shifting, it wont shift manually or in drive, its a 4l60(700r4) what else should i look for?
thanks
tony
Old Mar 20, 2004 | 08:14 AM
z28s's Avatar
ok, sometimes its shifting, sometimes its not
Old Mar 20, 2004 | 06:25 PM
12SCNDZ's Avatar
Something could have been missed or screwed up on the build. The governor could be sticking, or damaged. Usually, a stuck governor will still upshift manually, though.
A valve in the valvebody could be sticking (Most often the TV valve). The TV limit valve or TV upshift valve will also prevent upshifts.
YES, The TV cable has to be connected AND adjusted correctly for the transnission to operate properly. It's not just a "kickdown cable" on a 700...The cable controls the transmission pressure!
Frank
All-Trans Transmissions
Old Mar 20, 2004 | 11:16 PM
z28s's Avatar
i re-adjusted the TV cable, still nothing...
Old Mar 21, 2004 | 05:23 AM
ishz28's Avatar
The first time I had the tranny rebuilt, they couldn't get it to shift at the shop. They hooked some kind of computer controlled thingy to the tranny and they could get i to shift though the hook up controller. Found out it the PCU needed to be replaced.
Old Mar 21, 2004 | 07:20 AM
z28s's Avatar
my transmission is non-electronic, its just a 700r4 not a 4l60e
Old Mar 21, 2004 | 02:26 PM
z28s's Avatar
well, i think ive figured it out, i found a broken 2-4 servo spring...hope it works after i replace it tomarrow
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
