DTC 28 trany code
Old Feb 26, 2004 | 11:52 PM
Taylor's Avatar
DTC 28 trany code
I am getting a DTC 28
Transmission Range (TR) pressure switch assembly fault
I have a 93 with a 4L60. It shifts kind of funny. Shifts to early and doesn't down shift well, I have the TV cable adjusted right. The trans was rebuilt about 1.5 years ago by AAMCO before I got the car. What does this code mean? How do I go about fixing it?
Thank You
Taylor
Old Feb 27, 2004 | 09:54 AM
Taylor's Avatar
Anyone have a clue???
Taylor
Old Feb 27, 2004 | 03:50 PM
In the "93" setup, DTC 28 is a failure of one of the "Quad Driver" circuits. Not sure if that equates to the same code interpretation as the 94+ PCM code list, which you appear to be using. Maybe there is a 1-to-1 correlation on the 93 vs. 94+ codes, but someone with a 93 needs to confirm this.
Old Mar 1, 2004 | 02:29 PM
Taylor's Avatar
Hmmm, I was using the list off of Shoebox's website.
Taylor
Old Mar 1, 2004 | 11:19 PM
Taylor
93 DTC code list is slightly different.
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
timmy39120
May 8, 2015 11:41 AM
dreamer1q
Aug 20, 2002 11:19 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
