just got the basic nx efi kit what else do I need?
Old Feb 23, 2004 | 11:01 PM
94irocz's Avatar
Wink just got the basic nx efi kit what else do I need?
I have a 94z28. Mods in the sig and a walbro fuel pump. What else do I need to make this work on an automatic car? Will a 15lbs bottle fit in the spare tire well? What all do I need as far as gauges and such. I plan on getting the genx2 upgrade. Any help would greatly be appreciated.
Old Feb 26, 2004 | 06:09 AM
94irocz's Avatar
anyone?
Old Feb 26, 2004 | 07:41 AM
rskrause's Avatar
Moderator
I wouldn't use N2O without a window switch. Unless you live in a warm climate, a bottle heater is very useful and if you want to be safe and consistent a pressure gauge is also nice.
Rich Krause
Old Feb 26, 2004 | 10:17 AM
Sneakin Deacon's Avatar
i was paranoid with my setup, so i had just about every safety feature i could think of.
got my window switch from harlan engineering, sprayed in 2nd gear and had the switch setup for 3000-5700. Fuel pressure safety switch. Oil pressure safety switch. Used an MSD retard box and ran a 100 shot with 2* of timing pulled. Also used a DynoTune bottle warmer, worked very well, it was pressure adjustable.
purge is more flashy than anything, but good to have if you accidentally leave the bottle closed and heater on!!!
a blow down tube is also a good investment, incase of said bottle closed, heater on situation, and it causes the 3000psi disc to blow it wont fill the car with N2O, itll dump it out of the car.
And yes, a 15lb bottle will fit in the trunk space, not sure of the tire well, i actually had mine in the front seat with me covered in a duffel back...but i like sleeper stuff like that.
Old Feb 26, 2004 | 11:34 AM
dobe's Avatar
window switch, heater, purge is nice. to play it safe on mine i retard the timing when it sprays...
Old Feb 26, 2004 | 06:38 PM
94irocz's Avatar
So pretty much get the genx2 upgrade and I'm good to go as far as equipment goe?. Of course it'll see a dyno for some tuning and such.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
Queens94z28
Dec 20, 2014 09:11 PM
