hypertech..power loss?
Old Feb 23, 2004 | 12:49 AM
Friscoz28's Avatar
From: looking at thick girls in san francisco in my camaro
ive read a previous post and it said that the hypertech will actually take away power...is that true i have an a4 2002
Old Feb 23, 2004 | 06:29 AM
teke184's Avatar
it COULD....
some guys lose hp and others don't
it really depends on other mods. from what i've read it is best on a BONE stock car
you would probably get use from it since yours is an auto so you can adjust the shifts and associated things
Old Feb 23, 2004 | 11:56 AM
Aklaim's Avatar
Without 93 octane, the tune that the hpp3 gives you is useless.
Old Feb 23, 2004 | 12:24 PM
Friscoz28's Avatar
thanks aklaim, i think u saved me 460 dollars
Old Feb 23, 2004 | 02:05 PM
coogsLS1's Avatar
does hypertech have any advantage for M6 guys?
Old Feb 23, 2004 | 02:24 PM
2001NBMZ28's Avatar
I used one for gears, fans, shift points, shift firmness, etc. Worked great, never tried their tune though. Frisco - you can get a used one cheap - I just sold mine for $130 - you can get one, try it, if your car doesn't like it you can return it to stock and re-sell it. Do you have RFG gas out there? If I remember correctly it has a different tune for RFG.
Old Feb 23, 2004 | 07:16 PM
JaysGone's Avatar
Worked fine for me. But the power is in the upper midrange and I dont shift much past 3000 rpm so I went back to stock tuning. I still use it for fans and tires size. If I had the spare change Id have gotten a Predator tho
Old Feb 23, 2004 | 07:32 PM
Friscoz28's Avatar
we have 91 gas here in cali
Old Feb 23, 2004 | 09:19 PM
robb4964's Avatar
91 works as well as 93 ..IMO , at least thats what I read . as long as its 91 up , it should be fine .
Old Feb 23, 2004 | 11:10 PM
Aklaim's Avatar
Unfortunately 91 octane wont cut it for the HPP3 tune. The HPP3 tune was meant to be used with 93, and if you try to use it with 91 it can ping, and then the computer will pull timing which equals into lost power. Now, I'm not saying that if you use 91 that it is guaranteed to happen, but it has and it will to some. For the same amount of money you can have somebody do a real tune specifically for your car using LS1 Edit and have much better results and much more power.
Old Feb 24, 2004 | 10:38 AM
watsonusa's Avatar
Their web site reflects that, and I called Hypertech and asked if 91 was risky to use. They didn't say "no", but didn't say "yes" either. Basically use at your ouw risk....The Tech I talked to did say they were working on that issue and might come up with programming for us poor bastards that can only get 91 at the pump. Soooo, it looks like I'll be taking that portion of the programming off my car.
Old Feb 24, 2004 | 02:23 PM
Geeterman's Avatar
Get the predator, I got it and I like it. You can tune your a/f ratio yourself with it if you don't like the stock tune and it has everything hypertech has but more.
Nutty's96
Dec 21, 2015 06:25 AM
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
BlackSixSpeed
N2O Tech
Jan 2, 2003 11:29 PM
Mister Will
Nov 22, 2002 10:00 AM
