set up ildle speed
Old Feb 21, 2004 | 08:14 PM
jakesnake123957's Avatar
set up ildle speed
Hey s.a.tx. guys I have a 94 z-28 lt1 with all the bolt on mods,it ildles at 1100 rpm and it is a a4.Could someone lower it for me,thanks>jake.
Old Feb 21, 2004 | 08:35 PM
Dan K's Avatar
Are you sure it is the computer that is making it idle that high?
Are you sure that it really is idling that high, not just by reading the tach?
Has the car had any programming done before that you're aware of?
An A4 shouldn't idle that high, but odds are it isn't the computer commanding that high of an idle speed.
Old Feb 21, 2004 | 08:59 PM
It has had pcm reprogrammed,it runs good but I have to put in neutral to stop, when I put my other stock pcm in it ildes at 780 RPM,thanks>Jake
Old Feb 21, 2004 | 11:48 PM
Hal Fisher's Avatar
Send me your .bin/lt1 file and I'll take a look at it to see whats out of wack. There is no really setting idle speed so something is just a little whacky somewhere low.
Hal
Old Feb 22, 2004 | 12:19 AM
Dan K's Avatar
Huh? There are two tables that set idle speed in my version of tunercat?
Old Feb 22, 2004 | 01:14 AM
97Z-M6's Avatar
mine too. funny huh,,, maybe we are special customers.
Old Feb 22, 2004 | 06:12 PM
Dan K's Avatar
[ralph wiggum voice] I'm special. [/voice off]
Old Feb 24, 2004 | 12:24 AM
PatriotRed95z's Avatar
Hal Fisher
DAN K
Yes here are the 2 idle settings under the Tables heading ::
IAC Target RPM Vs. Coolant Temp, (In Drive)
IAC Target RPM Vs. Coolant Temp, (In Park/Neut.)
it worked for me , i set my idle up approx. 75 RPMs more...
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
737drivr
Feb 20, 2015 11:54 AM
hotrodyou1
Dec 20, 2014 10:05 PM
siguy
Nov 27, 2014 10:07 AM
