what kind of crank pulley/ balancer are you guys running?
Old Feb 10, 2004 | 07:39 PM
mehoffz24's Avatar
now that im geting this engine together i want to buy a new balancer. should i go with a oe replacement or aftermarket. WHAT would be the best choice. im running an eagle balanced rotationg assembly, mcleod steel flywheel and a d1sc 15# pulley. should i buy the expensive ATI balancer or will stock be just fine for that i want to do. i dont think ill have a problem with the stock one because everything is balanced but since you guys have the experience im open to all sugestions. thanks
Old Feb 12, 2004 | 09:03 PM
97WS6SCharged's Avatar
If it's a street car, I'd probably clean and coat the stocker and call it a day. The ATI balancer is a nice piece, and it's SFI approved to like 8 seconds in the 1/4 or something. If you've got a spare $400 bucks, go ahead and get the ATI.
Old Feb 13, 2004 | 02:54 AM
Vendetta's Avatar
I will be making the swap to the ATI super damper soon as well... I've heard very good things about it.
Old Feb 13, 2004 | 05:55 AM
rskrause's Avatar
Moderator
ATI, but you only need one if you are running above 6,000rpm.
rich Krause
Old Feb 13, 2004 | 06:44 AM
IDOXLR8's Avatar
I am still running the stock balancer without any problems. I shift my car at 6200 rpm.
Old Feb 13, 2004 | 10:33 AM
tubby's Avatar
i had a fluid damper. key word "had" until it came apart on the end of the crank. split at the keyway. switched to ati no problems to 7k.
Old Feb 13, 2004 | 11:08 AM
Vendetta's Avatar
I shift at 6500, which is my reasoning for the ATI.
Old Feb 13, 2004 | 11:51 AM
MSM69Z28's Avatar
same here with my fluidampr. cracked at the keyway. if you are gonna spend the money on the ATI, you may just have em send you the custom BBC OD ATI custom balancer. ID is SBC but OD is BBC. 5 times thicker hub for strength where most crack. about the same cost i believe and is most blowproof. lots of stress on the keyway groove with a big blower application. would require some mod to the cover for BBC seal. not a big deal though. just a thought for some added stability (especially if you are not double keying). lots never have problems, but if your gonna spend the $$ get the thicker hub. just my 2 cents.
mike
Old Feb 13, 2004 | 12:55 PM
bowtiepwr's Avatar
>I got my ATI Super Damper through Thunder Racing when they did a GP for us part #105-917271 I believe the price was around $340.00 or something .
Old Feb 13, 2004 | 07:50 PM
mehoffz24's Avatar
thanks for all the replys guys, i dont plan on reving past 6200 anyway. i think i will just buy a new stocker and call it a day. can i just buy the keyed hub from thunder racing and use that with the eagle crank?
Old Feb 13, 2004 | 08:10 PM
TimbrSS's Avatar
dammit, i got a fluidampr for my new setup, and now you guys got me all paraniod.
Old Feb 13, 2004 | 09:55 PM
Sean94Z's Avatar
Food for thought..
http://web.camaross.com/forums/showt...threadid=94281
http://web.camaross.com/forums/showt...threadid=94282
http://web.camaross.com/forums/showt...hreadid=202609
--Sean
HectorM52
Jul 30, 2017 11:46 AM
cmdeshon
Dec 27, 2014 10:06 AM
1996LT1Z28
Dec 1, 2014 01:01 AM
sleeperZ96BT
Aug 16, 2002 02:24 AM
Red97LT1
Aug 7, 2002 05:45 PM
