Whats your opinion on cold temp thermostat ?
Old Jan 27, 2004 | 09:51 AM
SpeedzAdisease's Avatar
My car has a running temp of about 175 not up around 210 where my buddy told me it should be. So it must of had a cold temp thermostat put in it. Are these bad for the engine ??? I think it might have had a power programer used on it which is fine b/c it is running great. I'm having the spark knock sensor replaced by a mechanic soon. If the battery or ecu is cut off could I possibly lose the power programer stuff ?? Some feed back would be cool fellaz.
Old Jan 27, 2004 | 09:54 AM
Buffdaddy's Avatar
I think that a cooler engine is better at performance.
Old Jan 28, 2004 | 06:37 PM
rncotton's Avatar
Greetings from Graceland! Hopefully things up in NashVegas are going well for you. If you haven't already done so, check up on the Middle Tennessee F-Body Association (www.mtfba.org)
As for your question, if you are running a lower temp thermostat, you won't see much difference unless you also do something to kick the fans on sooner. You can do that with a programmer, or by simply adding a manual fan switch.
If you are running a lot cooler than stock, then your guess is good that a programmer of some sort was used to kick the fans on sooner and take advantage of the lower temp thermostat.
Old Jan 30, 2004 | 02:15 PM
gun4hire's Avatar
Lightbulb
Mine runs pretty cool all the time, esp on the highway. The only time it goes up into the 210* range is in traffic.
HTH...
Old Jan 30, 2004 | 02:48 PM
RS Dragster's Avatar
From what I hear, LS1s are unlike other engines as far as what temp they like. Iron engines don't like the heat soak, a 160 or 180 would work great, but the LS1's like the higher temp. Several dynos have proved this. Like when I dynod my car, for example, the more runs I did consecutively, the more power she made.
So yeah, that's what I've always heard concerning LS1s.
Old Jan 30, 2004 | 08:31 PM
ULTIMTEORANGESS's Avatar
a tstat along with a fan switch and tune might get you a few more HP.im keeping my stock one for now.
Old Jan 31, 2004 | 01:47 PM
camaro322hp's Avatar
when you do several dyno runs back to back, many other things change in addition to the temp. it is a bad assumption to say that the temp caused the increase in peak hp...
simply because things happen concurrently does not mean that one caused the other...
Old Feb 1, 2004 | 12:13 AM
94ZRiCeKiLr's Avatar
according to multiple Autotap sessions, my car NEVER runs above 200 degrees EVER in any weather.....i have a stock thermostat with a hypertech telling the computer to kick the fans on for a 160 degree 'stat. this alone knocked about 20 degrees off my hottest stock temperature since the stock fan tuning turns fan 1 on at something like 219 degrees!!!
Old Feb 1, 2004 | 12:55 AM
stock fan tuning: fan 1, on at 227, off at 218. fan 2, on at 235, off at 228.
hypertech 180 t-stat tuning: fan 1, on at 194, off at 185. fan 2, on at 204, off at 195.
hypertech 160 t-stat tuning: fan 1, on at 184, off at 175. fan 2, on at 194, off at 185.
Biggiebound
Apr 23, 2015 08:50 AM
HCz28
Feb 15, 2015 03:01 PM
Jan 23, 2015 01:13 PM
Britbilly
Jan 7, 2015 08:49 PM
cmdeshon
Dec 27, 2014 10:06 AM
