Carburetor Questions. Plz Help.
Old Jan 27, 2004 | 05:35 AM
shocker45's Avatar
Alright, i have a 1967 Camaro ss. with a 355. 2.02 heads, i have a Holley 600 carb with new jets. Now the guy that did my carb for me didn;t know to much. and i basically know nothing about carbs.
So my question is this. What can i do to my carb that might make me lose a tenth or 2 in the 1\4 mile. I have a g-tech pro that i use, so far ive pulled a 5.9 0-60 and a 13.8 1\4 mile.
Is their any simple things i can do to drop some time?
And also, would pulling my air filter off just while im at the track help if i throw in bigger jets to help compensate for the extra air going in? i see tons of cars running no filters at the track. how much would it help?
Old Jan 27, 2004 | 01:03 PM
angel71rs's Avatar
If you have a well designed air cleaner, it might actually hurt to run without it. You should get a spring kit for the secondary cannister ( presume your 600 is a vacuum secondary). Especially if you have a K&N type filter; it drops less vacuum in the carb bores, so your carb opening point gets delayed.
If it's a double pumper, other than optimizing the jets, you would want to have some type of cold air routed to the inlet, either from a ram air setup, or a hood scoop.
Old Jan 27, 2004 | 01:51 PM
shocker45's Avatar
yea its vacuum secs and a double pumper.
what is a secondary canister exactly? like i said i dont know anything about carbs :P.
i dont want to get ram air cuz i dont have a lot of money to spend, so i wanna keep it cheap and simple. just by tuning and such.
and is that the only thing i can do?
Old Jan 27, 2004 | 08:49 PM
Duke79Zer's Avatar
[QUOTE]Originally posted by shocker45
[B]yea its vacuum secs and a double pumper.
It can't be both.If it has an accelerator pump for the primaries and the secondaries it is a double pumper,if it is vaccum secondaries there will be a vaccum canister on the right side of the carb.A double pumper and a vaccum secondaries carb are two different types of Holley's.
Old Jan 28, 2004 | 01:14 AM
shocker45's Avatar
well, dont i look like an idiot. this is why i want to learn more about carbs. k im pretty sure its vacuum, but im not 100%.
so what could i do to it to play around with my times?
Old Jan 28, 2004 | 02:41 PM
Z28SORR's Avatar
Buy this book!!!
http://www.amazon.com/exec/obidos/tg...glance&s=books
Old Jan 28, 2004 | 02:47 PM
jg95z28's Avatar
You can also try throwing a bag of ice on your intake manifold before you make a pass. (Seriously.) It's an old racer's trick that's proven to help out on ET's.
Jeff1904
Jun 5, 2016 05:00 PM
Kinglouui
May 26, 2016 11:05 AM
David Dempsey
Mar 12, 2016 12:42 AM
surreybrad
Sep 29, 2015 09:00 PM
colts0455
Sep 11, 2015 06:16 PM
