Fuel Pump Question
Old Dec 18, 2003 | 12:02 PM
SantaCruz163's Avatar
Fuel Pump Question
On a intercooled S/C 383 running at 15+psi, and a 150 shot what would be a good fuel pump and injector size to run? Also what kind of ignition would be needed to see full potential of power?
Old Dec 18, 2003 | 12:56 PM
IDOXLR8's Avatar
I would highly recommend doing a search on this subject or you can wait for Rskrause to chime in.
Old Dec 19, 2003 | 01:01 PM
bowtiepwr's Avatar
Re: Fuel Pump Question
>give Jack at www.racetronix.com a ring he's very knowledgeable
since he does that for a living ... after all he's a sponsor .
I will tell you what I run :
I have a LT1 (396) with 83# injectors using LJs Impedance converter , MSD boost a pump with their 6AL and boost retard controller . This is with the Vortech T-trim and 75 shot N2O .
as for the fuel pump I used : http://www.racetronix.com/Racetronix..._Pump_Kit.html
I hope this helps and I didn't leave anything out .
Old Dec 19, 2003 | 02:56 PM
rskrause's Avatar
Moderator
I used a 255lph Bosch in-tank with a Kenne Bell "Boost-a-Pump" and stock lines/regulator for a 733rwhp boost + nitrous combo and had a 11.8-12:1 AF ratio on nitrous. But it was maxed out. When I went for a more powerful setup I did a twin external pump system that I can give you the details on if you like.
You will need big injectors. I am running LJ's impedance converter and 90lb'ers. They are probably overkill but it idles fine with them. The WOT duty cycle is ~70%. So that's my advice in that regard.
I have no apparent ignition problems with an MSD box, Optispark, Accel coil, and stock wires. I am using very cold plugs (an 11 heat range) and have had no fouling problems.
Rich Krause
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
