Paxton Supercharger
Old Dec 16, 2003 | 07:48 PM
gritter's Avatar
Paxton Supercharger
how much hp boost will i see at the wheels if i bolted a paxton supercharger w/ a 6 lb boost to my stock 94 trans am a4?
Old Dec 17, 2003 | 09:26 AM
MEAN LT1's Avatar
Re: Paxton Supercharger
Depending on the wether and elevation, you may see 5-7.
Old Dec 17, 2003 | 01:48 PM
gritter's Avatar
Re: Re: Paxton Supercharger
5-7 hp boost from a supercharger?!
Old Dec 17, 2003 | 04:54 PM
Roadie's Avatar
no, 5-7 psi of boost.
you should see about 80 rwhp with everything stock. headers will help you get to 100-110rwhp out of it, but I doubt you'll fit headers on with a paxton kit (unless you do something like this.
Old Dec 17, 2003 | 05:13 PM
SMOKNZ's Avatar
That looks like an outstanding way to heat the intake charge!
Old Dec 18, 2003 | 08:25 PM
95 Silver TA's Avatar
Old Dec 19, 2003 | 11:00 AM
Roadie's Avatar
ha ha.
Everything's jet-hot coated, so the heat generally exits the exhaust... I also have a suncoast predator hood that just lets air into the engine compartment and heat extractors to let it out the back.
At 6psi on the dyno, I saw 137* IATs at 80* ambient temp with high humidity (STL area). For a non-IC setup, I ain't complaining. The air don't stay in the intake tubing long enough to get heated.
Old Dec 19, 2003 | 11:22 AM
Thats actually pretty damn good for a 6 psi set up, My friends powerdyne with 6psi would see like 150 degrees on a ~90 degree day at ~120MPH. Just to let you know, I was not laughing at your set up but more of the funny comment that was made.
Thx,
Claude
Old Dec 19, 2003 | 04:51 PM
Roadie's Avatar
I know it was a joke, hence the
I spent a whopping $1000 on the entire setup, so I'm definitely happy with what I got... I'll just upgrade head units later (low compression motor coming together) and the superfueler and MSD box will work with whatever I drop in.
I'm planning on selling the paxton head unit, brackets, and pulleys to recoup most of the money... If I get my dead 6BTM repaired and get ahold of any brand FMU, I could sell it as a whole kit to someone in the $750ish range... Maybe charge an extra $100 for the custom slip-fit primary for hooker/jet-hot long tubes to go with it.
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
rideordie
Sep 7, 2015 08:22 AM
