I need a diagram or schematic for wiring bottle heater...
Old Dec 8, 2003 | 08:29 PM
snksknr94's Avatar
I ran the wires up to where I have the switch mounted but I need to wire in a relay. Anybody have a diagram for this?
Old Dec 10, 2003 | 02:24 PM
snksknr94's Avatar
If nobody has a diagram can somebody just try and explain it to me. I have a good understanding of how it should work, just want to make sure it is right.
Old Dec 11, 2003 | 06:31 PM
slow's Avatar
it is simple, you need a relay, the relay will have 4 pins
30 power in
87 heater out
85 control 1
86 control 2
For the 30 pin, connect to battary with 10 gauge wire, fused of course
For the 87, your "load" goes to the heater.
The 85 and 86, one goes to ground, the other to +12 when you want the heater on.
Connect the switch on the +12 side of the relay, and your set.
If your heater has a thermostat, or a pressure sender, connect that between the relay, and the ground, where it says "control" on the chart below.
+12-----Switch------relay------control-----ground.
Ryan.
Old Dec 11, 2003 | 08:53 PM
TravisA's Avatar
Why would you need a relay?
Travis
Old Dec 12, 2003 | 03:37 PM
Serene's Avatar
If you are using a pressure/temperature switch you need to use a relay. Its always a good idea to use a relay instead of switching the main feed to the item.
Old Dec 15, 2003 | 03:33 AM
slow's Avatar
most switches are not rated for 30 amps that a heater can draw
Ryan.
Old Dec 24, 2003 | 09:49 PM
Tofus 93Z28's Avatar
exactly
relay= electromechanical device that allows a small current to control a large current....
or magic smoke can be let out.......
Apr 27, 2015 06:08 AM
surreybrad
Apr 22, 2015 06:40 AM
titanthomas
Apr 18, 2015 11:44 PM
EdgarArmada
Apr 18, 2015 05:20 PM
blac94Z
Mar 20, 2015 09:58 PM
