What can I safely spray with a wetkit .
Old Dec 13, 2003 | 05:50 AM
2ZPOINT's Avatar
I know most spray 100-150 but what about 175. Can I get away with it with just an inline fuel pump added. The motor does have 4 bolt mains but I believe it has hypercraptic pistons. the crank and rods are stock.
Old Dec 13, 2003 | 05:52 AM
Transamdriver's Avatar
175 is pushing it, it has been done before though. 150 is the limit that I am willing to spray on my engine.
Old Dec 13, 2003 | 06:42 AM
RacinLT1's Avatar
i ran a 175 with a 255lph intank pump. im not a big fan of inline pumps with the stocker in the tank mainly due to the inline has to pull through the smaller stocker.
If your tuneup is dead on,175 wont be a problem,but dont run it on pumpgas and make sure you run cold plugs.
i was going to try a 200 shot,but the trans had different ideas and the output shaft broke.
Old Dec 13, 2003 | 07:49 AM
Brent94Z's Avatar
Super Moderator
Moving to the Nitrous forum...
Old Dec 13, 2003 | 09:43 AM
Derrick Redd's Avatar
Ditto. I've ran the 175 shot also without issues. Just make sure you have a good tune and proper fuel.
P.S. I don't like ju-ju beans or jawbreakers.
Old Dec 13, 2003 | 03:08 PM
DrewHMS97SS's Avatar
i wouldnt push it with your pistons. i would personally stay 125, because i like my car to run. it is possible to run the bigger shots, but your motor will be like a time bomb.
Old Dec 13, 2003 | 05:30 PM
steelheart's Avatar
i spray a 150 wet shot all day long and the motor really feels like it wants more, the 150 shot doesnt even phase it, and im doing this with autolite 104's and no inline pump and no saftey equipment you should be fine with a 150 shot, 175 then i would go 2 ranges colder on the plugs and mix a few gallons of race gas in the tank
Old Dec 14, 2003 | 02:12 PM
no offense, but no safty eq, that doesnt really say too much about you. and how do you know the motor feels like it want more. ive seen 3 or 4 lt1s pop with a 150. you are just sitting on a bomb, and when it happens, think of this thread.
(at least get safty stuff!)
Old Dec 14, 2003 | 04:38 PM
steelheart's Avatar
i dont need saftey stuff, i control the button with my finger so the saftey is on me not some micro switch that can get stuck or a missed shift at wot, why rely on on saftey euip that could still possibly fail, i trust my finger...
Old Dec 15, 2003 | 02:27 AM
what about when your finger works but your fuel pump goes. POP!
Old Dec 15, 2003 | 05:12 AM
RacinLT1's Avatar
you can have all the safety stuff in the world and still hurt parts with any power adder.
i never run a FPSS(once in the last 10 years i did,annoying pos),cant stand em. i do put in a good fuel pump,so dont feel a need for a fpss. i also dont run a window switch,i spray through shifts,for maximum et gains.
Basically it's confindence in your knowledge and equipment.
when i sprayed the 175,i pulled 3 degree's of timing,and had no detonation,150 i pulled no more then 2 degree's.absolutely no signs of detonation on either setup.
Old Dec 15, 2003 | 06:19 AM
steelheart's Avatar
like racinlt1 said, i feel confident with myself and my car so you have to trust yourself and not rely on saftey equip all the time, and chances of a fuel pump just going 'pop' is like a million to one
Old Dec 15, 2003 | 02:33 PM
i guess if you trust that your fuel will be there everytime, then by all means.
motor = too much $$ for me to not think of murrphy.
Old Dec 15, 2003 | 05:23 PM
steelheart's Avatar
with a wet kit the fuel is always there, thats why i dont even waste my time with a dry kit, dry is too risky for me
Old Dec 15, 2003 | 08:20 PM
it all relies on the same fuel pump. if the pump goes, the nitrous keeps spraying.
