what happens if the oil oulet is level or slightly lower than oil pan??
Old Dec 4, 2003 | 05:05 AM
LT1RX7's Avatar
I'm now getting to hook up the oil lines and realize that my turbo is just about even with the oil pan. Will this create a huge problem? I'm using 5/8" hose which is about 24" so it's plenty big but just slightly has a dip in the middle.
Old Dec 4, 2003 | 10:30 AM
Tiago's Avatar
unproper oil drainage which you will have will result in oil leaking past the seals and going into your exaust and intake , so you burn oil , and leak oil, alot.
Old Dec 4, 2003 | 11:04 AM
LT1RX7's Avatar
so how can I fix this without relocating the turbo? Is there a small electric oil pump I can buy? There's got to be a way if the rear mounted turbos work
Old Dec 4, 2003 | 11:31 AM
Tiago's Avatar
gotta find a oil scavaging pump.... Im not sure where u can get one.
Old Dec 5, 2003 | 03:22 AM
LT1RX7's Avatar
if I use a crankcase vacuum pump than wouldn't the oil in the the dump line just get sucked into the oil pan?
Old Dec 5, 2003 | 03:45 PM
SMOKNZ's Avatar
Precision sells one I believe, one of the board members use one, I probably should have used one on my old turbo tech kit.
Bill
Old Dec 5, 2003 | 04:26 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
i know its off topic, but I couldnt help but find it funny that when I saw this topic, the last response was from a user named "smoknZ"
cause that is exactly what it will do
Old Dec 6, 2003 | 02:57 AM
96 WS6's Avatar
I had a puff of white smoke the other day when started my car... and a couple nights ago I smelled the same smell I got when that puff came out. I thought that it was just a one time thing but it occured to me that this could be the problem after I read this thread. Best I could my vortech drain is about level with the oil pan with no dips in the line. Think that's good enough??? I drove the car to my girlfriends house today and so far so good. Could it be possible that running it with the drain like that for a short while (probably less than 500 miles) messed up my blower seals??
Old Dec 6, 2003 | 03:19 PM
SMOKNZ's Avatar
Thanx dude!
Actually I had that user ID way before I had a turbo. The car didn't smoke
Bill
Old Dec 7, 2003 | 04:55 PM
arnie's Avatar
Originally posted by LT1RX7
if I use a crankcase vacuum pump then wouldn't the oil in the the dump line just get sucked into the oil pan?
No, or at the VERY LEAST, do not expect it to. Not to be used for that purpose or gain.
You do have options regarding specific scavanging pumps. I'll give three. One is a pump from Tilton. One is a pump 'revamp' of an existing product from Westech in Texas. The third: http://www.batinc.net/files/pump.pdf
Edit: 800 posts! Unreal! I gotta believe, Brent is trembling, feeling me breathing down his neck!
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 31, 2015 07:29 PM
LTOne4Fun
Sep 10, 2002 07:48 PM
94redform
Sep 8, 2002 03:27 AM
