injector offset vs. Battery voltage table
Old Oct 19, 2003 | 08:07 PM
Schurters LT1's Avatar
Should you change this when you got to 30lbs svo and what do you put it to?
thx
Old Oct 19, 2003 | 10:57 PM
madwolf's Avatar
I found that stock offsets seem to work best with an injector change. Perhaps the calculated values available on some pages are not quite correct. (I've also looked at them many times through time and they are often updated, sometimes with radical changes... that's why I don't trust them)
Just use the stock offsets, but don't forget to set the injector value to 31.6. (SVOs were rated at 39.2 PSI and we run 43.5)
Old Oct 20, 2003 | 02:56 AM
TA25th's Avatar
Thanks! Great info...
Do you know if the Bosch 30b/hr Fuel Injectors are the same as the Ford Bosch SVO 30lb injectors? Here is a link to some...
http://www.lt1f-body.racenet.net/induction.php
They are the 280150945 and have the red tops on them.
http://personalpages.tds.net/~kpevin/inj.jpg
Thanks,
Shawn
DirtyDaveW
Dec 1, 2016 05:37 PM
Bxlt1
18
May 27, 2015 05:00 PM
nosliw
Apr 26, 2015 02:13 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
