Why not Propane?
Old Aug 19, 2002 | 03:19 PM
Snowmann's Avatar
Post Why not Propane?
I have heard of some nitrous kits for Vipers with propane injection,why not for the F-Body. Lots of pros but no cons,
It wouldnt be putting a load on the fuel system,cools the intake charge,would flow good in a EFI manifold, as it is a gas right, and it has like 104 octane rating right? Seams a little silly that no one has offered it, there must be a reason though. Has anyone seen or heard of results from a viper with this setup? Still doent understand why we cant get it if the viper can.
98 Z28 A4 2.73 aluim. driveshaft
Free mods SLPlid & bellows
BMR LCA & SFC
Stock: 288rwhp 311rwtq
Old Aug 19, 2002 | 03:37 PM
97f1z28's Avatar
Post
I know thare isn't one for the LT1 yet,but there is a system for the LS1 vette. I am sure it could be adapted for the LS1 Camaro or Firebird.
97 Z28 Convertible
A4, K&N CAI, Flowmaster cat back, TB bypass, MAF descreened, Transgo Shift kit, BM trans cooler, BMR strut tower brace, BMR subframe connectors, 3.73 GM motive gears, TA Girdle, Y2K vette rims, SLP quad in the center exhaust
Waiting For install
BMR Panhard rod, AFPR, Hypercoil springs
http://camaroz28.cardomain.com/id/97f1z28
Old Aug 19, 2002 | 03:40 PM
Snowmann's Avatar
Post
Do you know who makes the kit?
BMR LCA & SFC
Old Aug 19, 2002 | 04:04 PM
97f1z28's Avatar
Post
It was the same company that made it for the viper. I will see if I can find the link.
Old Aug 19, 2002 | 04:07 PM
Snowmann's Avatar
Post
That would be great, I dont know what I would do without this board.
BMR LCA & SFC
Old Aug 19, 2002 | 04:08 PM
97f1z28's Avatar
Post
http://www.btrviper.com/vetteproducts.php
Old Aug 19, 2002 | 04:24 PM
Snowmann's Avatar
Post
Sweeeet, I emailed them for more info. Kit looks kinda spendy but it might be worth it. Now that I know its available for the LS1 anyone ever use this or here of anyone use it on a LS1?
BMR LCA & SFC
Old Aug 20, 2002 | 12:17 AM
speedmiser's Avatar
Post
Actually, I see more disadvantages with propane than advantages.
The big 2 being - monitoring and refilling another bottle.
Why even bother? You dont need more than 93 octane pump gas to run a 70-150 shot on a stock compression ls1. If you just want something different, then that's understandable. But if you're lookn for functional, then an NX or TNT kit would be a much better choice for the money. In fact, you could seriously upgrade your fuel system for extra coin the propane kit would cost.
I'm not trying to discourage you from something you want to do - I just see it as more $$$ and more hassles, with no hp gains over a basic wet kit.
Good luck with whichever route you decide to take.
If I'm playin, I'm sprayin
93 Z28 A3 - w/ Jet Hot coated Hooker LT's and true 3" duals
(hiflow cats, cutouts, and Car Chemistry insert mufflers)
[This message has been edited by speedmiser (edited August 20, 2002).]
Old Aug 20, 2002 | 08:48 PM
a walker's Avatar
Post
Another disadvantage is that propane is a flammable gas, where nitrous isn't.
Blue 1994 Z28
Moroso CAI, March underdrive pulleys, Jet throttle blade, Comp Cams 1.6 rr, Accel 300+ ignition, HPPIII, Accel adjustable fuel pressure regulator/gauge, Nitrous Works wet kit (175hp), FLP race-prepped 4L60E, Coan 2800 rpm convertor, LS1 driveshaft, 4.10 gears, cat removed, Flowmaster American Thunder. Moser 12 bolt soon.
Old Aug 21, 2002 | 08:47 AM
SmokinHawk's Avatar
Post
There starting to make propane kits for turbocharged vechiles to replace alki injection. these kits are cheaper the btr's, there around $500 or less. these can be adapted for nitrous kits using a WOT switch
99 TurboTransAm
T-76 TT single
#5 @94 octane
385/430 mustang dyno
Old Aug 30, 2002 | 03:22 PM
NVMYZ28's Avatar
Post
What does NHRA say about Propane tanks in your trunk?
Jeff C - Utah
1994 383 Z28 M6
Bored, Stroked, Splayed, and Sprayed!
www.nvmyz28.com
Utah F-body Assoc.
Old Aug 31, 2002 | 08:10 PM
BBB's Avatar
BBB
Post
Propane injection is a HUGE deal in performance diesels. (Yes performance diesel trucks can be very scary fast.) Do some searching in the areas of Cummins Turbos and Power Strokes and you can get some info on propane injection.
BBB
Old Sep 2, 2002 | 08:04 AM
Chris Ja's Avatar
Eternal Member
Smile
w
[This message has been edited by Chris Ja (edited September 02, 2002).]
Old Sep 2, 2002 | 05:41 PM
got_hp?'s Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by SmokinHawk:
</font>
www.dynamicracing.com made their own propane kit after the owner tried it on his viper. they have also used it with great success on turbo 3000gt's and supras.
pros of propane:
1 increases octane
2 lowers knock
3 cools intake temperature
4 one 5lb bottle lasts a LONG time
5 CHEAP to refill, and can be refilled almost anywhere
cons
1 it can blow up
3000GT VR4 TT *sold*
new project, 95 t/a....will someone make a good turbo kit already?!?
wyldcdn
N2O Tech
12
Jul 22, 2008 09:18 PM
LS1M
Advanced Tech
11
Jul 14, 2004 11:15 PM
944v8inDFW
N2O Tech
13
Jul 5, 2004 12:29 PM
tireburnin
N2O Tech
11
Feb 24, 2003 01:28 PM
