propane as a extra boost
Old May 16, 2008 | 10:27 PM
wyldcdn's Avatar
I've searched and sent PM's out to those who have tried Propane as a fuel additive/extra shot with the NOS. No replies. So here I am.
So far what I've learned is the ratio is 10:1 for Nitrous to propane. Now to inject this into the motor directly or with the wet shot on the propane (or gas) Should I add a Y fitting (at the nitrous line going into my plate, so both Nitrous and propane are on at same time and injected at same location?) then use the according size jet for the propane?
Maybe use a seconday plate. Or inject the propane after the MAF and spray it in with the incoming air charge?
HELP, I'm tired of chasing faster cars.
Old May 27, 2008 | 11:36 AM
drperformance's Avatar
put bigger nitrous jets in! you will get the added boost you are looking for
Old May 27, 2008 | 12:40 PM
northdakota93z28's Avatar
the red rooster booster, that was used in the 50's for farm tractors to give them some more power. it was propane. i dont know any gas stuff that people use propane, just diesels.
Old Jul 4, 2008 | 04:20 PM
Hootiez28's Avatar
There was a guy on here (andy m..... not sure of last name) who was running a stock to the exhaust manifolds lt1 on a nitrous/propane mix in the high 10s. Hopefully he'll chime in.
Old Jul 4, 2008 | 04:51 PM
wyldcdn's Avatar
sent him a pm same time as i made this post never have..I've gotten the info i need
one day i'll get it on the darn car..LOL
Old Jul 5, 2008 | 09:59 AM
Propane/nitrous is a popular kit for the Viper. I've seen one installed and dyno tested. Same company that makes that kit also makes it for the Corvette.
http://www.btrviper.com/nitrous.html
http://www.btrviper.com/vette_products.htm
Old Jul 5, 2008 | 12:40 PM
wyldcdn's Avatar
injuneer...........................thank you
Old Jul 12, 2008 | 12:21 PM
andy katzelis's Avatar
The links injuneer provided should give you all you need.
And, let me take this opportunity to thank Injuneer for providing the technical infomation he does on his website. Thank you (well written and easy to understand). I reference it often.
Old Jul 12, 2008 | 12:28 PM
Thanks for the positive feedback.
Old Jul 12, 2008 | 01:19 PM
wyldcdn's Avatar
you're always helpful
Old Jul 14, 2008 | 06:29 PM
jakesz28's Avatar
If your going to do it you have to use a wet nozzle or plate. On the gas side you hook up the propane instead of your fuel line. The fuel soleniods are not realy designed for the 160-180 PSi the propane will be at. I have some notes here on some jetting which you could start from. It seems like a few people started with the same size nitrous and fuel jet then leaned it out till the plugs looked good.
Are you limited by the fuel pump or do you have the misunderstading that you will make that much more power with the propane? The main advantage is propane is a little higher octane but you could do a 1 gal stand alone fuel sytem for the nitrous and run 110 in it.
Old Jul 14, 2008 | 10:38 PM
wyldcdn's Avatar
reason for propane was more for higher octane, better distribution and no fuel soak.. Any info you can pass on is great
Old Jul 22, 2008 | 09:18 PM
Technically, propane should make less power as it displaces incoming air. I never had any problems making power and every power level produced what I expected it should.
I do think there is some merit in improved fuel distribution, especially with the LT1's dry intake design.
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
