what pressure to set fpss
Old Jul 17, 2002 | 01:43 AM
Carson 94 t/a's Avatar
Post what pressure to set fpss
I just got my fpss and want to hook it up but how do i get the arming pressure ing range.
94 T/A t-tops, a4 !maf screen shorty headers !cat flows
Old Jul 17, 2002 | 09:26 AM
Post
What pressure you set it to depends what kind of N2O system you are running (e.g. - wet or dry) and what your fuel system looks like.
If you are asking how to set the switch, I mount it in a "tee" on my air compressor line, put a VOM meter across the terminals and adjust it until it goes on ands off at the pressure I want.
Fred
94 Formula A3: 381/TH400/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Old Jul 17, 2002 | 09:43 PM
Post
<font face="Verdana, Arial" size="2">Originally posted by Injuneer 94FormM6:
</font>
thanks i have a wet system so about what psi should it shut down?
Old Jul 19, 2002 | 02:48 PM
95ImpalaSS's Avatar
Post
I would suggest hooking up a fuel pressure gauge and monitoring your WOT fuel pressure, then set the fpss about 2 PSI below that. If you find it cuts out too often, drop it another pound or two. If it still cuts out, you need to look into a bigger fuel pump.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
F(ast)-body
Feb 26, 2003 09:05 AM
