I have a 73 camaro engine where is my voltage regulator?
Old Aug 25, 2002 | 02:00 AM
Pegasus's Avatar
Post I have a 73 camaro engine where is my voltage regulator?
Sorry for such a stupid question...But where exactly is the voltage regulator for the 70-73 camaro engines...Or did they even have any?
Old Aug 25, 2002 | 10:35 AM
Damon's Avatar
Post
I haven't futzed around on an old Camaro for a while but the regulator on my friend's 72 Chevelle (worked on last month) was mounted up on the radiator support behind the driver's side headlights. Square black box with a buncha wires attached to it.
bestracing's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Pegasus:
Sorry for such a stupid question...But where exactly is the voltage regulator for the 70-73 camaro engines...Or did they even have any?</font>
On my 72 it was located on the radiator support on the driver side in the engine compartment. It is about 2" square in sizes and it has three bolts holding it on the side of the support. Hope this helps.
Wayne Best
Best Racing
67 rs Camaro
  • 355 cu in Chevy
  • 12.5:1 compression
  • 10.90s @ 120 mph
87 Formula 350 w/388cu.in. motor
www.geocities.com/best_racing
Old Aug 26, 2002 | 05:15 PM
91-RED-WS6's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by bestracing:
</font>
Ditto on my '73 (before I pulled it all apart)
Old Aug 28, 2002 | 10:35 PM
rscamaro73's Avatar
Exclamation
It SHOULD be on the INTERNALLY REGULATED alternator.
How many wires do you have ? One under a rubber boot, and 2 on a pluf that fits in the side of the rear, correct ???
If you NEEDED an ext regulator, then it'd be on the firewall, and the alt would have 2 sets of plugs (2 wires each) attached.
ME-73LT 454
99 Hugger Orange V-6 (for sale)
San Diego F-bodies
Old Aug 28, 2002 | 11:02 PM
MadMike's Avatar
Post
Camaros built after February 73 have an internal voltage regulator. Prior to this they were external (on the radiator core support).
pete53
Dec 9, 2014 07:31 AM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
slothgrant
Aug 22, 2002 03:01 PM
Eric H
Aug 10, 2002 06:39 AM
