Battery not charging, must be a short somewhere?
Old Aug 6, 2002 | 04:02 PM
Barry68Camaro's Avatar
Post Battery not charging, must be a short somewhere?
Hey guys, the other day, the wire that runs to the alternator decided to fall down and get cut by the fan belt. As it did that, it shorted out the voltage regulator, I mean that baby was toasted. Anyway, I replaced the voltage regulator and to my surprise the generator light is on. I thought maybe it was the alternator so I replaced that too and the light is still on. What gives? What could be causing the generator light to stay on? The battery is definitely not charging. What else should I check?
Old Aug 9, 2002 | 12:07 PM
Greg Nolte's Avatar
Post
Check the terminal behind the battery and the wires from there to the regulator
Cranberry Red 69
SS Convertible
95 LT-1 / 4L60E
Old Aug 11, 2002 | 11:22 AM
chenoweth316's Avatar
Post
Check to see that the battery is in good condition, this happenedto me just voernight, and the battery was in there for nearly 9 months when it decided to do this, the bottom bolts that hold the battery try down poked a hole in the bottom of the battery and drained one of my cells, it would not start on its own, but a boost would fire it up and it was driveable but when i shut it off, that was it. Hope this helps. Make sure all your cells are full of juice.
Vehicle- 1978 Camaro LT yellow, purple racing stripes, 350 inside, Edelbrock Intake, Edelbrock 600 cfm carb, Comp Cams Camshaft, dynomax exhaust, 3" tips, 9"x5" K&N Air Filter sticking through the hood, 3.73 Rear end gears and more to come.
Stereo-Pioneer Head Unit with 3-d dot matrix display, MTX Thunder 302, 425 watts, 2 12" Rockford Fosgates in a sealed box, 2 Crystal 6x9, and 100 watt amp for them.
Pics- www.geocities.com/chenoweth316/camaro.html
http://community.webshots.com/user/chenoweth316
grabbem88
20
Dec 27, 2015 07:42 PM
jwade88
Jun 14, 2015 09:38 PM
eanhl2004
Apr 4, 2015 12:01 PM
97z28k&N
Jan 9, 2015 04:58 AM
Decromin
Aug 18, 2002 10:11 AM
