How much boost could I run?
Old Aug 6, 2002 | 09:11 PM
Tang's Avatar
Post How much boost could I run?
How much boost with a supercharger can I run with a stock 81 Z28? Thanks
Old Aug 6, 2002 | 09:50 PM
AJ1978TA's Avatar
Post
Stock 81 Z's have low compression, which is good for a blower/turbo, but holy crap, if its stock, it's 21 yrs old, and if you put a blower on it, the car, will, well, blow up......Don't do it. You can't just bolt something on like that.....you need all forged components, like crank/rods/pistons/pushrods etc etc.......and a whole bunch of other stuff I can't even list or think of.....
Old Aug 6, 2002 | 10:25 PM
70 Cam Guy's Avatar
Post
It would be easier and probably cheaper in the long run to go another route to find your extra power. With boost, it would be a sound idea to get an air/fuel mixture guage because if it leans out detonation can happen. Also iron heads don't mix well with high compression and pump gas. I'm not really sure why but thats what my speed shop told me.
Boost is no friend to a cast bottom end (pistons/rods mainly). You usually have to build an engine around the blower so it will run like it should
Andy
aim: Andyman350
1970 Camaro - Its running and is tons of fun
pics of me and stuff
Old Aug 7, 2002 | 09:56 AM
BartonekDragRacing's Avatar
Post
I wouldnt worry too much about rods and the crank unless you're gonna push lots of boost.. Forged pistons yes. stock rods w/all the work done will be fine if you keep the RPM's 6k and below. I'm running a SCAT 5140 crank, stock rods and TRW forged pistons..it'll hold up. Pushrods..buy some $100 pushrods..no junk on those. I agree with 70 Cam Guy on building the engine specifically for the blower.. BTW, which kind? roots, centr. ?
"Get Blown Or Get Blown Away!"
1968 RS Camaro
383 w/6-71 10#, Dart heads, 4.88 spool, gutted.
Bartonek Drag Racing
Old Aug 7, 2002 | 07:32 PM
Tang's Avatar
Post
Thanks for your replies. First off I was thinking of a roots type blower. But after what you all said I think I'll either just buy a crate engine and drop it in or build up an awesome N/A engine. But I might think about the blower still.
DirtyDaveW
Dec 1, 2016 05:37 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
cmdeshon
Dec 12, 2014 10:51 PM
Brady
Jul 29, 2002 10:30 PM
