My 88 jeep is stuck in first? Please help! :)
Old Sep 2, 2003 | 10:04 PM
raxxus's Avatar
Unhappy My 88 jeep is stuck in first? Please help! :)
Hey you guys my jeep ripped the pinion and ujoint a block away from my house. Anyways I took out the driveshaft and drove it home in 4WD (some fluid came out). Well it sat in front of my house then today I pulled it up in the garage, took out the pinion, then got in the jeep and reversed it out. Well when i went into first it would not go anywhere, like the front wheels were stuck. I tried 3rd gear also. Well i just reversed the other direction and stopped. My question is did i just **** up my transmission or what . Im going to put in the driveshaft and fill up the fluid, could it just be the fluid? thanks
PS when it is off and it is in neutral and its in N for the stick that changes it from 2H 4H N 4L it still wont budge, it can only go in reverse
Old Sep 2, 2003 | 11:02 PM
viperkiller's Avatar
i may be tired but i didnt understand xactly
can you push the jeep forward and backwards. or does the engine bog when you try to drive it. if so does it bog even with the transfer case in -n-
Old Sep 2, 2003 | 11:08 PM
raxxus's Avatar
I cant push it forward at all even wit hthe transfer case in N, but it will go reverse .
i havent tried to drive the jeep wiht the transfer case in N but i'll try tomorrow firs tthing
68camaroboltz
Oct 5, 2015 11:56 PM
Jul 17, 2015 02:47 PM
sherwinZ28
Jun 6, 2015 08:48 PM
BLK1997Z28
May 2, 2015 01:26 PM
titanthomas
Apr 18, 2015 11:44 PM
