whats wrong with my reaer diff?
Old Sep 2, 2003 | 02:18 PM
krillanaross's Avatar
I was looking at my car today trying to find an oil leak, and i noticed something on top of my rear diff. I dont know what it is, but it is plastic and it slides in and out freely. And theres quite a good amount of oil that has been spraying out of it. Anyone able to help me???
Old Sep 2, 2003 | 02:46 PM
95GRNZ's Avatar
Arrow
Not sure what that plastic thing is, but are you sure it is not your pinion seal that's been spraying the fluid all over?
leaking rear pinion seal is very common with LS1 F-bodies.
TS
Old Sep 2, 2003 | 02:47 PM
how would i figure that out w/o taking it to a shop?
in case you cant tell im kindof in the learning process.
Old Sep 2, 2003 | 03:39 PM
pg318's Avatar
If you don't have traction control, there's a speed sensor in the top of the housing, which should be held down by an M6 screw.
Old Sep 2, 2003 | 03:43 PM
is it like an almost greenish color? and thats what i meant the housing...sorry. and its on the passenger side. would that be it. If so, would it cause oil to spray all over the back underside of my car?
Old Sep 2, 2003 | 04:15 PM
CODY BEHNKE's Avatar
Thats the vent tube.
Old Sep 2, 2003 | 04:17 PM
why would the vent tube spray oil everywhere?
Old Sep 2, 2003 | 05:37 PM
chpmnsws6's Avatar
a vent tube is to vent air/oil so it doesn't build to much pressure
Old Sep 2, 2003 | 06:21 PM
is the vent tube supposed to just slide completely out of the housing though??? The oil must be from something else because theres like mass amounts of oil....maybe ill just have a shop look at it.
Old Sep 2, 2003 | 07:36 PM
Yes it can just be pulled out, who changed the fluid last? If it was severly over filled it will build up pressure and come out the vent.
Old Sep 3, 2003 | 01:48 AM
AL SS590 M6's Avatar
Moderator
It's very common for the vent to leak fluid. Pull it out and clean it up with brake clean or something simular. Take a small piece of cloth soaked with the cleaner and clean the hole that the vent fits into. When everything is dry put some silicone sealer around the base of the vent near the shoulder and reinstall it. It won't leak any more.
Aaront810
Aug 29, 2020 09:34 PM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
Aaront810
Sep 11, 2015 11:24 AM
