Car wont crank
Old Aug 24, 2003 | 10:48 PM
03RSIX's Avatar
Car wont crank
Gotta problem here. car will not crank. will run when pop started. only lights on the dash are the abs inop light that was not there before. car did this out of the blue battery is good. is this somethign electrical or the solenoid on the starter?
Old Aug 25, 2003 | 02:42 AM
scoobysnax83's Avatar
Well, if it runs fine, but you can't get the starter to engage, there's only a few things that it could be. One the starter, two the solenoid, three the ignition switch. Best bet is to test voltage at the starte. If no voltage, then its the ignition switch if you do have voltage then its starter related. Its easier and almost the same price to replace the starter and solenoid. I believe Autozone sells them as one unit.
Queens94z28
Dec 20, 2014 09:11 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
1LEThumper
Jul 14, 2003 12:45 PM
