94 Camaro LT1 hesitation problem
Old Aug 24, 2003 | 04:39 PM
mrxz28's Avatar
Unhappy 94 Camaro LT1 hesitation problem
I own a 1994 Camaro z28 LT1 w/ 51k miles. Sometimes when I put my foot into the throttle the engine spitts - hesitates - coughs - pukes sputters and so on. I installed a new fuel filter and this did not work. I run only 93 octane premium fuel no ethynol. Any helpfull suggestions would be great
Thanks, Mark
Old Aug 24, 2003 | 04:43 PM
Red96Lt1's Avatar
Does it sound like a leaky valve or a fuel problem?
If you said it coughs, that sounds like a problem with the heads to me.
Old Aug 24, 2003 | 06:32 PM
94formulabz's Avatar
Worse when its warm?
replace the following in this order.
coil
plugs + wires
optispark (expensive)
I did coil plugs and wires at the same milage and it fixed my stutttttter.
Old Aug 24, 2003 | 07:02 PM
naaz90's Avatar
My Z had bad hesitation about a year ago. New plugs and wires fixed it. I just installed a new opti about 50 miles ago during my water pump replacement and the hesitation is back. theres a new opti in the mail.
Listen to what 94formula said, do the easy stuff first, if that dont work get an opti from Jason Cromer.
Old Aug 24, 2003 | 10:52 PM
Fatdog's Avatar
Cool
Coil wire.Do the cheap stuff first.My02(n=most noticeable at high rpms.)Replace it as a normal maintenance thing.Every 6 months or so.Hope this helps.
Red Hawk 94
Mar 18, 2019 04:03 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
siguy
Nov 27, 2014 10:07 AM
IRABuss
Sep 7, 2011 09:08 PM
1LEThumper
Jul 14, 2003 12:45 PM
