Will my LT1 rear brakes fit on my new 2000 rearend?
Old Aug 17, 2003 | 10:51 AM
DarkHorse's Avatar
Guys, got a big problem here. I'm leaving in a few to bolt up my new rear - a 2000 3.42 rear. Problem is I don't have the rear rotors from the 2000. Can I use my stock 94 rotors on this rear? What do I need to change over brake wise? Thanks
Old Aug 17, 2003 | 11:04 AM
Mike94ZLT1's Avatar
everything, the brakes are completely different. 98 and up used a drum in hat setup as the parking brake.
Old Aug 17, 2003 | 11:13 AM
DarkHorse's Avatar
What about swapping my entire backing plate assembly? Calipers pads and rotors + the backing plate.
Old Aug 17, 2003 | 11:51 AM
EviLZ28's Avatar
You can do that. You just need to switch everything from your old to the new.
Old Aug 17, 2003 | 12:59 PM
You will also have to swap the old axles from your existing rear end. The axles are slightly different lengths.
Seems like it would just be easier to get a pair of new rotors.
Old Aug 17, 2003 | 03:51 PM
S8ER95Z's Avatar
Yep I have the rear Auburn unit from a 98 WS6 and they only used the gears and housing.. Axles, Brakes, etc were all swapped.
Old Aug 17, 2003 | 04:51 PM
DarkHorse's Avatar
Thanks guys. Decided to hold off on the install until next weekend. Nobody had rotors for 2k in stock so I thought a swap would be easier, seems not.
ddr698
Jan 9, 2015 10:05 AM
Jazsun
Dec 29, 2014 12:14 PM
bossco
Nov 29, 2014 10:18 AM
vals95z
Mar 18, 2003 03:45 PM
