Hmmmmm?
Old Aug 11, 2003 | 11:55 AM
IXLR894Z28's Avatar
Hmmmmm?
There is a rattling (for lack of a better description) coming from my gear shift lever or that area only in first or second gear. Once I hit third it goes away. Could this be due to low fluid? There is no problems shifting my car and my clutch is not slipping, this is more of an irritance. Any suggestions will be greatly appreciated.
Old Aug 11, 2003 | 12:00 PM
Ichoptop's Avatar
there should be a bushing (either nylon or delrin) at the shifter base. It sounds like that it has split causing excessive play in the shifter when pulled to the far left. I would pull the boot and insulation mat of and take a look at it.
Old Aug 11, 2003 | 12:04 PM
IXLR894Z28's Avatar
Would I feel the play? Because the shifter is tight in all positions.
Old Aug 11, 2003 | 12:25 PM
Ichoptop's Avatar
that wouldnt be it then. when mine split it would flop around like a dead fish everytime I hit a bump.
markmc59
V6 Tech
Apr 2, 2012 09:25 PM
Josh452
16
May 31, 2007 08:33 PM
bullman911
Jun 17, 2003 12:35 AM
Maldo
Apr 16, 2003 09:54 AM
