where to get window motor
Old Aug 10, 2003 | 08:04 AM
98 PURPLEHAZE's Avatar
OK i am mad now both of my windows don't go down. I am going to fix them after work today. where do i buy the motor and is there a left and right one. also i think i have a instruction guide but can somebody post the link just in case thanks guys
Old Aug 10, 2003 | 02:49 PM
SpecForceZ28's Avatar
Autozone should sell them,
and I believe they come with a lifetime warranty
Old Aug 10, 2003 | 02:54 PM
Slappy3243's Avatar
Whatever you do, don't get another one off a wrecked F-body. It will just break again.
-Adam
Old Aug 10, 2003 | 03:15 PM
DS01Z28's Avatar
Or, try A-1 Electric at:
www.a1electric.com
Daryl
Old Aug 10, 2003 | 03:35 PM
thanks i went and got it from autozone.
Old Aug 11, 2003 | 10:41 AM
Ichoptop's Avatar
what did you end up paying for it?
Old Aug 11, 2003 | 10:43 AM
Constrictor98TA's Avatar
I bought the Siemens motor from Autozone and paid around $75 for it. It works well and goes up and down faster than the stock one did.
Old Aug 11, 2003 | 10:48 AM
therealmagyver's Avatar
Discount auto parts.
Old Aug 11, 2003 | 11:30 AM
Ichoptop's Avatar
mine made a nice pop then same crunching noises. Sounds like plastic gears getting untoothed. I havent had the doores opened up yet so I dont know where the gears are located. 1 as part of the motor and 1 as part of the regulator asst?
Old Aug 11, 2003 | 01:09 PM
I ENDED UP GETTING THE SEMIENS ONE FOR 50 BUCKS. has anybody done an install before...how hard is it and can you give me some tips.thanks
Old Aug 11, 2003 | 02:20 PM
I changed mine. Not hard at all once you've followed the write ups that are available. There is a link with pics and instructions. Just do a search and you will find it. If this site doesn't have it check the other 2 big sites.
Old Aug 11, 2003 | 02:21 PM
Speedy Dragon's Avatar
Advise: Need two people. One to hold up the HEAVY window and the other to take out the motor. The motor is rivet'ed to a bracket that is attached to the gear. Its makes things much easier if you take out the whole assembly and work on it. Once its out just pop the old on out attach the new one and install back. Otherwise you will be doing it blind because the Motor is behind the door itself. Plus I don't know about you but I don't like to drill what I can't see. Make sure also before you put the trim back to make sure the window goes up and down smoothly(otherwise you are going to be getting yourself a new motor). There is very little supporting this window to guide it and it is very heavy hence why so many motors die. Not a bad design just not the greatest.
Seth
Old Aug 11, 2003 | 02:33 PM
http://csce.uark.edu/~jgbertr/rb/alt...ndowmotor.html
I didn't need anyone to help me. You can hold up the window with a board or even a shoe like I did. Goto the above link and it will show you how to do it.
I did my install by myself in about an hour. It really is not hard. I made a walkthrough and it is over at www.metalreviewcentre.com/window.htm
Unfortunately, most of my pictures are offline for the next couple days, but the text is still there. I will have it back up this weekend, but if you need to see the pictures before then, I can put em back online.
You dont need anyone to hold the window up, there is a convenient hole at the top of the door you can shove something into to hold it in place. I used an empty tennis ball can. You can see it in the pictures.
Keenan
Jan 19, 2023 12:24 PM
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
