Runnin Lean....
Old Aug 13, 2002 | 07:58 PM
BoscoZ28's Avatar
Question Runnin Lean....
My SES light is on, so we ran the codes and the car is running lean. It looks like the fuel psi is around 30. The car has 51,000 miles, what should I do? I was thinking its either the fuel pump or the pressure regulator. Which one do you think is the problem is? If they need replacing, is there any recommended brand? Thanks for the help
Old Aug 14, 2002 | 04:27 AM
PhantomTA's Avatar
Moderator
Post
There really isnt a regulator.
So its the fuel pump
DaveD
1998 WS6 #207
-ARE Stage II Head/Cam
1998 Regal GS
-It Has Boost
The Phantom of CamaroZ28.com
Http://PhantomTA.cz28.com
Old Aug 14, 2002 | 07:44 AM
BoscoZ28's Avatar
Post
Thanks for the reply, I guess Ill try the fuel pump. From what I have read, its not a direct replacement, there is a little bit of modifying requierd, can anyone tell me what exactly is required? Thanks agan
Old Aug 14, 2002 | 10:13 AM
TheDogofWar's Avatar
Post
or maybe a bad filter or dirty/clogged injectors. Do you have any mods? you can flip your MAF for a temp fix.
Old Aug 14, 2002 | 09:43 PM
BoscoZ28's Avatar
Post
We replaced the filter and ran fuel injector cleaner in our last 2 tanks of gas, but still no luck. What does flipping the MAF do?
trinydex
Jul 4, 2003 04:54 PM
CamaroRob97
Jun 25, 2003 07:20 AM
red 95 z28 lt1
Jun 14, 2003 11:14 PM
JONEZ_Z
May 5, 2003 07:21 AM
pacesetter
Classic Engine Tech
Apr 25, 2003 07:59 AM
