Woodurff Keys???
Old Jul 19, 2003 | 12:01 AM
InjectedSS's Avatar
Woodurff Keys???
can you just use the ones that you see at the hardware stores or do u have to buy the expensive ones??? ive seen the ones at the HW store for like $0.24 and theres some in performance catalogs for like $10.00
Old Jul 19, 2003 | 12:41 PM
Jeff Belloma
Guest
Posts: n/a
what are the keys doing?
the only diff i can think of is in the metal alloy. types used for high loads are generally made from a steel with more nickel content to make them tougher. if it's just for a pulley (not supercharger) then the hardware store types should work fine. crankshafts should get a tougher key though.
JB
Old Jul 19, 2003 | 12:48 PM
InjectedSS's Avatar
JB
yea these are for the TWO keyways in the crank! one for the crank timing gear and the other for the harmonic balancer!
Old Jul 19, 2003 | 01:17 PM
notstock4long's Avatar
I would say go with the one you know is right. We had to replace them on our sea-doo once after it locked up and broke them. And plus, the ones at the hardware store might be a little different size that you can tell by looking at them.
Old Jul 19, 2003 | 06:47 PM
InjectedSS's Avatar
well their definately the right size thats not my concern! my concern is WILL they be strong enough or should i go with something different?
Old Jul 20, 2003 | 08:19 PM
Don 97 SS's Avatar
I installed a keyed hub on my crank snout when I replaced the cam recently. I just used a key that fit. The hub it press fit anyway and I don't have a blower.
68camaroboltz
Oct 5, 2015 11:56 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
