Ever so slight stumble off idle...where to start looking?
Old Jul 18, 2003 | 10:51 PM
Timberwolf's Avatar
99 Z, 65k miles. I know the cat is going, it is occasionally throwing a code.
Just yesterday it started a very slight stumble when coming off idle. Some probably wouldn't notice it. But I do. Also a slightly erratic idle when coming to a stop at a light or something. Like I said, not real noticeable, but I can feel it...
Is this something that is common? Anyone point me in the direction to look?
Old Jul 19, 2003 | 07:18 AM
Timberwolf's Avatar
ttt
Old Jul 19, 2003 | 09:55 PM
ZIPPERR's Avatar
Have you tried inspecting the plugs and wires?
Old Jul 19, 2003 | 11:34 PM
Pentatonic's Avatar
The rougher idle were my symptoms when my cat was going bad, but I didn't have any sort of stumble off idle.
Inspecting the plugs would be a good idea. If your car is throwing a code, have it scanned in at auto-zone. This will help diagnose your problem, since the computer also recognizes something is not normal.
Old Jul 20, 2003 | 12:44 AM
AL SS590 M6's Avatar
Moderator
I already scanned it for him it's the bank 2 cat. Would the cat being bad cause the car to stumble like he's describing?
Old Jul 20, 2003 | 01:17 AM
ZIPPERR's Avatar
I think so. Cat might be broken up inside restricting flow causing the stumbling. I Would have this fixed/replaced before anything else.
Have you heard any popping from exhaust while driving?
Old Jul 20, 2003 | 10:02 AM
Timberwolf's Avatar
nope, nothing from the exhaust at all. The ct problem just started as near as I can tell in the last week. And the stumble in the last 2 days. I wondered if they were related, but it seemed more like a vacuum like or ignition just based on prior experience with other cars. I guess if the cats causing it I'm gonna need those o2 sims Al so I can get the ORP in there
Old Jul 20, 2003 | 12:32 PM
Pentatonic's Avatar
If the cat is restricting the flow enough, I would guess it could cause a stumble off idle. Replacing the O2 sensors with O2 sims isn't going to help the problem at all if the cat is bad.
You will probably need to have a new cat installed. Although, you might get lucky, and it could be just the sensor.
Old Jul 20, 2003 | 12:34 PM
Timberwolf's Avatar
Nope, the sims ould go along with the ORP.
(off road pipe)
Old Jul 20, 2003 | 12:46 PM
ZIPPERR's Avatar
Remember, Cats have like a 6 year warranty. I would just have those fools at the dealer check to see if the cat is actually bad or not.
Old Jul 20, 2003 | 09:59 PM
Moderator
Ok I'll save them for you.
karnykamaro
Feb 2, 2015 01:37 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
cristian1311
Nov 23, 2014 02:22 PM
IRABuss
Sep 7, 2011 09:08 PM
Dave19yz28
Jan 26, 2003 01:45 PM
