switching to th400 ?'s
Old Jul 18, 2003 | 05:16 PM
amean94ta's Avatar
i know to get th bmr cross member and trans but what then do you need to do anything for a kick down cable or just run a manual valve bodie alone and what about speedo and computer
Old Jul 31, 2003 | 07:49 PM
amean94ta's Avatar
i know someone here knows
Old Jul 31, 2003 | 08:58 PM
rskrause's Avatar
Moderator
You run the speedo the same way as any F-body, off a reluctor and a sensor (magnet) that is installed in the tranny. The M6 crossmember can be modified fairly easily to use with the TH400. Most people use a manual valve body. You may want to do a search, this has been discussed here a lot.
Here's what you need. I may be leaving some stuff out.
-transmission
-flexplate
-manual valve body
-dipstick
-oil pan (may not come with tranny)
-tranny cooler
-crossmember
-VSS (speed sensor as above)
-driveshaft
-shifter
-slip yoke
-torque arm (you need one that does not mount on the tranny)
-PCM reprogram to read speed correctly
-torque converter
-auto pedal assy (you can use the 3-pedal assy if you wish)
-transbrake (if desired)
-tranny shield (if desired)
Rich Krause
Old Jul 31, 2003 | 09:49 PM
Fast S/C '94Z's Avatar
you can the speedo parts off a 1991 truck with a th400, and as for the kickdown you can run a microswitch off the throttle body, there are other option besides manual valve bodies
Old Aug 1, 2003 | 09:17 AM
tubby's Avatar
while your on the subject of speedos. i have the reluctor wheel installed on mine. i need the wire and plugin to go to the comp.. can i just use the one off a '91 truck also?
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
