will LS1 eibachs work on a LT1???
Old Jul 30, 2003 | 03:20 PM
97SS0594's Avatar
i ordered eighbachs off ebay, well come to find out there for 98+ cars, but i didnt think there was a big diff between the LS1 cars and the LT1 cars, does anyone know if i can install these???
Old Jul 30, 2003 | 03:36 PM
stereomandan's Avatar
Actually, they are what Sam Strano recommends I believe. He is an autocross National Champion, and knows his stuff, to say the least. Maybe he'll see this post and chime in.
Dan
Old Jul 30, 2003 | 04:53 PM
sc1twntrbo's Avatar
i belive is that there the same except that the ls1 springs are softer in teh front because of the weight dif in the frotn of the car
Old Jul 30, 2003 | 05:07 PM
buelldevil's Avatar
SPL parts are the same for both.
Old Aug 1, 2003 | 07:14 AM
97SS0594's Avatar
well i put the ls1 springs on and i love the handling!! it rides like a rollerskate but for the new handling i can deal!!
Old Aug 1, 2003 | 08:29 AM
BlownF1's Avatar
I'm running the LS1 fronts on my 95. It results in a slightly lower stance, maybe .100"-.200" since they're a tad bit softer, but other than that everything works and fits fine.
Old Aug 1, 2003 | 08:33 AM
KCFormula's Avatar
Eibach lists two different part numbers for the LT1 and the LS1. However I bought my springs used so I don't know where they came from.
Old Aug 1, 2003 | 08:35 AM
If you go to the autocross section of this site, I have a thread going about Eibach springs. There are spring rate numbers there for both sets of springs. Also a link to a bunch of good data.
Dan
Old Aug 1, 2003 | 08:41 AM
DR.ZED's Avatar
Yuppers.
The rears are the same drop at the LT1. The LS1 kit drops .1" more (1.6" as opposed to LT1 1.5"), to compensate for the 60 lbs in saved weight with the LS1 motor.
However, my front springs give a lower stance more than .1" it appears than the LT1 kit on the LT1. I liked it so much, I suggested it to a buddy who did the same.
However, just like SOTP meter, I haven't measured it... so I could be talking out of my azz.
I've had no issues, except the occasional rub on full lock turn in reverse to the plastic wheel well.
Old Aug 1, 2003 | 09:18 AM
Here's the spring info.
Stock spring specs are:
Front: 292 #/in
Rear: 112 #/in
There are two Pro-kits offerered for fourthgens.
LT1 Pro-kit specs:
Front: 377-600 #/in
Rear: 94-160 #/in
LS1 Pro-kit specs:
Front: 400 #/in
Rear: 80-137 #/in
The LS1 kit is better in my opinion because the front springs are linear rate. That is what shocks are designed for.
Dan
rideordie
Nov 5, 2019 04:52 PM
ddr698
Jan 9, 2015 10:05 AM
Dec 1, 2014 08:08 AM
ChrisFrez
Nov 23, 2014 10:33 AM
