switching to th400 ?'s
i know to get th bmr cross member and trans but what then do you need to do anything for a kick down cable or just run a manual valve bodie alone and what about speedo and computer
i know someone here knows
Originally posted by amean94ta i know someone here knows Here's what you need. I may be leaving some stuff out. -transmission -flexplate -manual valve body -dipstick -oil pan (may not come with tranny) -tranny cooler -crossmember -VSS (speed sensor as above) -driveshaft -shifter -slip yoke -torque arm (you need one that does not mount on the tranny) -PCM reprogram to read speed correctly -torque converter -auto pedal assy (you can use the 3-pedal assy if you wish) -transbrake (if desired) -tranny shield (if desired) Rich Krause |
you can the speedo parts off a 1991 truck with a th400, and as for the kickdown you can run a microswitch off the throttle body, there are other option besides manual valve bodies
while your on the subject of speedos. i have the reluctor wheel installed on mine. i need the wire and plugin to go to the comp.. can i just use the one off a '91 truck also?
