Spraying out of the hole with a 4000 stall
Old Jun 8, 2003 | 09:45 PM
z2894convertible's Avatar
I keep hearing dont spray under 3000 rpms. I have a Vig 4000 stall. Would it be ok to spray out of the hole with this. Since I will be above 3000 rpms. I will be spraying a 100 shot for now and closer to winter I am going to a 150 shot. I also have a stock bottom end.
Old Jun 8, 2003 | 11:18 PM
stik6shift93's Avatar
All you'll need to get is a window switch, it only allows the nitrous to come on in a specified rpm range. You adjust this through the use of pills, you just put in a 3k pill and it won't let you spray until you hit 3k rpms .
Old Jun 9, 2003 | 05:41 PM
funina91ss's Avatar
Take this for what its worth I dont even recomend you try it but its what works for me. I dont use a window switch I hit it off the line with a 3k stall did the same with the stock stall to. I pull. 1.79 60ft on motor and 1.63 on a 150 shot.
Old Jun 9, 2003 | 07:58 PM
Derrick Redd's Avatar
I don't have a window switch either. I launch off my 3,600 stall. Best 60ft. so far of 1.55.
Old Jun 9, 2003 | 09:10 PM
It doesnt seem to me that a 3000 window switch would serve much purpose if I am running a stall bigger than 3000
Old Jun 21, 2003 | 09:10 PM
Can someone correct me if I am wrong?
Old Jun 21, 2003 | 09:13 PM
funina91ss's Avatar
I wish I had one when my car dont want to shift it hits the revlimiter (MSD) I would like to have it cut off the juice before it but I have never had a problem with it like that. and it hits the revlimiter alot
Old Jun 21, 2003 | 09:18 PM
Sounds like your tranny is going bad
Old Jun 22, 2003 | 12:25 AM
funina91ss's Avatar
Nope I have a case of the OBD1 blues 3k stall 1.63 60ft = no shift for me but I am working on that. I just ran a 02 Z06 he pulled me about a 1/2 car out of the whole and I ran out of juice. on the top end. and we stayed the same.that was on the 2nd run the first run I had juice and it looked like John Force doing a burn out The trans works flawless on the street
Old Jun 23, 2003 | 10:55 AM
My convertor is sized to flash to 5K rpm under an 800ft-lb hit. Basically, stall it up to 2,500 on the foot brake and floor it when the lights drop. The 800ft-lb will have it at 5K rpm in millseconds! No problems. No lower limit on the RPM. Then just hold on..... .
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
4586
Jul 31, 2015 06:03 PM
detroitmuscle
Jul 31, 2015 04:21 AM
Boss002
Jul 24, 2015 10:47 AM
