how hot do headers really get?!??!
Old Jun 7, 2003 | 02:24 PM
1995redZ28's Avatar
just finished installing my hooker lt's... but im paranoid about all the wires!! the drivers side is fine, i re-routed the abs wire and everything else is out of the way. but the pass. side is making me nervous. what did you guys do with the abs wire?? it has NO slack and pretty much cannot be moved. i just used heat reflective tape and cover the whole area.
now what i really want to know is how close to the headers do wires have to be to melt?? i mean wires are about an inch away, but is that too close?? does the wire actually have to touch the header itself to melt? im just trying to do this right the first time. anyone have any input or experiences with burning wires other than plug wires?? thanks in advance!
Old Jun 7, 2003 | 02:33 PM
atalay's Avatar
Use heat shield around all of the wires and do it as soon as possible!! An inch to headers for ABS wires is very close!! I have SLP shorties and they get HOT!!!
Old Jun 7, 2003 | 04:40 PM
revtime's Avatar
I rerouted both my ABS wires in my 94 and did not have to extend them.
Move the wires out of there, extend them if you have too.
I spent about 4 hours extending and rerouting wires, I was not hurrying by the way, if you do it now you will have alot less problems in the future.
Starter wire, Knock sensor and ground I extended and ran under the motor mount. O2 sensors I extended and rerouted.
Old Jun 7, 2003 | 04:49 PM
blown383's Avatar
I extended my wires out of the way also...but the Jet Hot long tuebs don't get nearly as hot as the stock manifolds did....strange but its true.
-B
Old Jun 7, 2003 | 05:11 PM
JKDZ28's Avatar
headers get really hot.... by the time you get done turning the key and walk to touch them ... they will be hot
as long as the wires are not directly touching they shouldnt burn.... but make sure they arent touching
Old Jun 7, 2003 | 05:57 PM
blown383's Avatar
JKDZ28 huh? Does your f-body pak sao and trap very well?
-B
Old Jun 8, 2003 | 04:08 AM
revtime's Avatar
They call him Bruce.
Old Jun 8, 2003 | 08:41 AM
Don 97 SS's Avatar
I think an inch away is fairly safe, but I don't take any chances. I carefully route wires and use tie wraps to hold wires where I want them to be. I alao own about every sort of wire insulation product that MSD and a few others sell. I use them liberally.
Old Jun 8, 2003 | 09:54 AM
anasazi's Avatar
an inch is plenty of room
you saw how my wires were routed, some wern't too far away at all. i think the minimum distance i had was about 1/2 of an inch, and that wire was covered with heat reflective tape.
1 inch is tons of room
Old Jun 9, 2003 | 01:06 PM
HtownZ's Avatar
i dont think the stock wires will make it through all that heat, the best way to go is with an Acccel wire. these are the best wires when you're using headers. you should have gotten coated headers!!!!!!!!!!!!
Old Jun 9, 2003 | 01:41 PM
xxsaint69x's Avatar
according to my EGT guage, at wot my headers get up to umm 1350
HarleyZ28
Oct 5, 2015 06:23 AM
Drtryder
Apr 22, 2015 04:17 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
