car poped and died and code p1371 quick question about the opti
Old May 11, 2003 | 11:57 AM
white97T/A's Avatar
I guees my opti crapped out -- sounds like similar symptoms that others had when their opti went south -- now my question is what part do I need to fix it --- O'Reillys said it comes in 2 pieces cap and rotor, and the opti part -- whatever should I get both parts or one or the other
Old May 11, 2003 | 12:19 PM
Get a whole brand new GM unit from Jason or Dal. You will be a lot happier. ~$200 since you have a vented opti.
Dal Slabaugh: 877-448-5451
email: lockitup@bright.net
VanDevere Buick/Pontiac/Olds Akron, OH
Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept)
email: gmparts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
Old May 11, 2003 | 12:24 PM
white97T/A's Avatar
why would I be alot happier - arnt they the all the same? it is about $250 from Oreilly and I could have it today. if it is not the same quality I will order one, but I really need the car to get around so I would like it fixed asap
Old May 11, 2003 | 12:39 PM
Is that $250 for cap, rotor and base section? Probably rebuilt (I don't know that for sure). All the same? I doubt it.
The GM one is brand new, complete and ready to bolt on.
Your call. Many people have tried the aftermarket opti stuff and ended up spending twice as much when they got the GM unit because the other did not hold up. Some have had good luck, too.
Old May 11, 2003 | 01:21 PM
white97T/A's Avatar
yes it is $250 for the cap rotor and base section.
Old May 11, 2003 | 01:25 PM
white97T/A's Avatar
ok I called Oreilly back and it is a remanufactured Opti that they offer
Old May 11, 2003 | 08:12 PM
white97T/A's Avatar
I stared to remove the opti and need to know how to get the harmonic balancer off. do I need a pulley puller or what?
Old May 11, 2003 | 10:30 PM
The pulley and the hub are two pieces. You only need to remove the pulley. If it won't come of with a little persuasion, you can use a puller to remove it. Put the mark on the hub at 12 o'clock and you will have room to remove the opti.
You might want to check out this site, too.
Old May 14, 2003 | 11:29 PM
white97T/A's Avatar
HELP
Ok I replaced the coil and the opti, and the car still wont start. please give me some suggestions. I am getting spark from the coil now (which I was not getting before) but I am still not getting spark to the plugs. what gives?
Old May 14, 2003 | 11:34 PM
Test your coil wire with a meter to be sure it is good and be sure you have the plug wires on correctly . You will hear a couple of clicks when the plug and coil wires are inserted all the way into the optispark terminals.
Old May 15, 2003 | 07:56 PM
white97T/A's Avatar
more info: when ever I try to start the car a couple of times, the intake gets filled with smoke -- it comes out throught the throttle body is this indicitave of anything?
Old May 15, 2003 | 10:46 PM
Could be that you did not get the opti lined up correctly when you installed it or you have plug wires crossed. If you are getting some smoke out of the intake, sounds like at least some plugs are getting fire, just maybe not at the right time.
Old May 17, 2003 | 12:29 AM
white97T/A's Avatar
shoebox, thank you so much for all of your help. I got the car running like a champ now. the problem was that indeed the opti was not lined up like it should have been -- the dowel some how got into the wrong area.. anyway i got that corrected and it is running perfect
Old May 17, 2003 | 12:32 AM
white97T/A's Avatar
oh and btw i ended up getting a brand new opti from Dal
Injuneer
Dec 15, 2014 09:36 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
Absolute Z28
Jul 19, 2002 02:21 PM
