Stopping SLP Shorty header leak
Old Apr 30, 2003 | 01:54 AM
Joe Brodman's Avatar
GP Moderator
This is NOT for my car (I have Hooker LT's), but rather for a friend of mine I'm helping with his 97 Z. I'm installing a 255LPH fuel pump and nitrous kit on his heads/cam car next week, and he wants some help fixing the leak.
He's running Felpro 1406 header gaskets, just like I run. Dunno what header bolts. He's tried the copper RTV trick around the primaries w/ no success. This last time, he tightened them so tight a couple started to strip their threads. Usually what ends up happening is the leak goes away for a bit, then ends up coming back.
So, I want to find a permenant solution for him. Stock gaskets? Doubled up gaskets? Perhaps a different gasket that works better w/ those SLP's.
I'm gonna re-tap all of the bolt holes. Mr. Gasket offers what looks like a pretty nice header STUDD setup we may try, though I wonder if the studds will clear all of the primaries, since the primary routing sucks a big one. If he wasn't tapped for cash, I'm sure he'd ditch these damn things for some long tube, but that's not an option.
Old Apr 30, 2003 | 02:16 AM
96 WS6's Avatar
I am using 1406 and they seal perfect with a little bit of rtv... the y pipe is a bitch though. I just ordered some stock gm metal gaskets to see if they will work.
Old Apr 30, 2003 | 04:37 AM
magius231's Avatar
you may want to examine the flanges and see if they are warped or something...or if hes got bolts loosening. I just put SLP's on mine, with 1406 gaskets, ARP header bolts and no sealant at all. When I started it up the first time, I drove it around a bit, parked it then retightened all the header bolts (they are really easy to get to for the most part). For that day and the next I checked them regularly (didn't really need to though) and now I'm tightening them once a week (again don't really need to but its better to be safe). I have yet to have a leak anywhere.
Old Apr 30, 2003 | 08:08 AM
MYT30TH's Avatar
I installed the 1pc. steel crushable gaskets w/ hooks on the end for easy installation ( no sealant ) GM p/n - 12550033 @ 13.00/e
Have been leak free for close to two-years , also re-torqued the ARP bolts about a month after the install.
Old Apr 30, 2003 | 08:27 AM
GREGG 97Z's Avatar
I assume he's using the SLP dual cat headers for his 97? I have the single cat style and I used 1" ARP bolts instead of the 3/4" SLP included in their kit. I think the 1" really reduce the chance of overtightening and stripping the head, if he's not using the longer bolts I'd get some. Also I used the Felpro 1406 gaskets and I have not had any problems with leaks for over a year now, I do go back over them every couple months or so to recheck them.
Old Apr 30, 2003 | 09:54 AM
Mystic95Z's Avatar
I had leaking problems when using the 1406's with my SLP shorties. I pulled those out and installed a set of Earls and haven't had a leak in over two years.
-Tony
Old Apr 30, 2003 | 10:09 AM
faded93bird's Avatar
I use the GM stock 94 gaskets
they are three lyar metel and fairly cheep too i dont know what list is but if you know someone they are cheep
all you have to do is trim of some metel tabs to work with headers
P/N 12552469
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jason Short
Jan 19, 2015 06:34 PM
Killer94z
Jan 13, 2015 12:06 PM
turbo_Z
Aug 19, 2002 10:50 PM
