How tight for header bolts?
Old Apr 21, 2003 | 04:29 AM
96z's Avatar
96z
How tight do you guys torque down your header bolts??? There is no way I can get a torque wrech in there with these Hooker LT's.
Old Apr 21, 2003 | 05:01 AM
magius231's Avatar
if you can get a torque wrench on one of them, then get a regular wrench on it and feel how tight it is...tighten the rest down to as close as you can. From Injuneer's install guide:
The spec for torquing them is 30-35 ft-lb (check-are these 3/8"-16?) using grade 8 bolts with oil, and 23 ft-lb using moly. I think the anti-seize most closely matches "moly"
Old Apr 21, 2003 | 11:18 AM
96z's Avatar
96z
Cool, thanks...Ill have to give that a try.
Old Apr 21, 2003 | 10:31 PM
Bud M's Avatar
With Stage 8s I tightened them tight with a short wrench (not much leverage) and have had no problems.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
