Power loss from rockers being too tight?
Old Apr 12, 2003 | 11:11 PM
Kreinmc's Avatar
I kept having this tick so i decided i would adjust them at 3/4 turn past zero lash. I am now sure the tick is a lifter. Sucks that i have aftermarket lifters that are already going bad. It is not a loud tick so i am going to let it go for awhile. Think it would be beneficial to back them off a little bit over a 1/4 turn?
Old Apr 12, 2003 | 11:33 PM
If you are nit picking, your car will most always make more power with less preload. For a street car, it is always a balance between power and noise.
Old Apr 13, 2003 | 06:31 AM
Don 97 SS's Avatar
Well said. To add a point, if the rockers are too tight you risk damage. Moreover, local engine builder/racer tells me that the power increase from slightly looser rockers can be significant.
Old Apr 13, 2003 | 12:35 PM
Kreinmc's Avatar
Just wondering because my car seems to not make very much power up top. I have been shifting at about 5900, but i would like it to pull hard all the way to 6300 without falling off. My 306's power band would never fall off lol.
Old Apr 13, 2003 | 02:20 PM
mycarisfasterthanyours's Avatar
I don't think a 1/4 turn on the rockers is going to net you any gains that you are going to feel. I think part of reason your car feels slow up top is because you are used to the 306. The 305 just isn't the same. If you want the torque down low and the drivability then you did the right thing switching to the 305, but if you want all the pull at the top then you should've left the 306 in there. The best compromise is what you really want.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
