what is involved with changing pistons, rods, and crank?
Old Apr 7, 2003 | 11:41 AM
sc93's Avatar
for a stock bore LT1 block. I was thinking of possibly down the road just switching to forged internals so I can run lots of nitrous or a supercharger. I assume the engine would probably have to be pulled, and rebalanced after the rotating assembly is put together.
Any input would be greatly appreciated
Old Apr 7, 2003 | 06:14 PM
This is sort of basic "how to" and should be posted on the Generation specific Tech board.... in this case "LT1 Tech".
Moving.....
Old Apr 7, 2003 | 06:55 PM
sc93's Avatar
I'm sorry about that Fred...
it seemed kind of advanced tech for me, I wasn't sure....
Old Apr 7, 2003 | 09:25 PM
rskrause's Avatar
Moderator
You need to pull the motor and inspect/replace some basic things before putting it back together. The correct order of things to check depends on exactly what your plans are. But I would plan on a fresh set of bearings, no matter what. Obviously, you will be using new rings with your new pistons. As long as the heads are off, I'd do a valve job. The issue of checking vs. just replacing things like valve springs, etc. depends on what tools are available to you, what your budget is, etc.
FWIW, a stock crank is pretty stout. You definitely need a good set of forged pistons for nitrous or a SC, but you need to decide which prior to a rebuild. A nitrous motor is typically high CR, while you will want a low CR for a blower car. Stock rods aren't bad, if you upgrade the rod bolts and if they are in good shape, but their adequacy will depend on exactly what you have planned and also on your budget.
I realize that's pretty general and rambling, but I am not really sure what you want to know.
Rich Krause
Old Apr 7, 2003 | 10:25 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Rich Krause
In other words-
its a rebuild
if your going to spray alot, good rods are a good idea
Old Apr 7, 2003 | 10:30 PM
treyZ28's Avatar
Rich Krause
In other words-
its a rebuild
if your going to spray alot, good rods are a good idea.
Crank is good so long as Rpms dont get too happy
Old Apr 8, 2003 | 06:52 AM
sc93's Avatar
Thanks for the info guys
RUENUF
Mar 13, 2016 03:39 PM
Dmonty
Jun 2, 2015 11:19 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
kev93z28
Aug 19, 2002 12:48 AM
