What to expect from combo
Old Apr 6, 2003 | 08:21 AM
john35thss's Avatar
Just waiting on my lt4 210 race heads from afr but have everything else. Here goes:
A.R.E. 383 eagle 4340 crank and 5.7 rods
je reverse dome(-31cc) pistons
milodon main caps
comp custom grind 232 248/ 602 614 solid rollor
888-16 lifters
afr 210 race heads
lt4 intake 58mm bbk throttle body
50 pound racetronix injectors twin 255 racetronix intank pumps
sq trim vortec kit with 6.66 crank pulley and 3.33 charger pulley
crane ignition (can with charger) OBD1 computer A.R.E. tuning
strange 12 bolt with 3.73 gears
lingenfelter alum driveshaft
stock 6 speed with mcloud street twin
All this is going into a 1996 TA and it's just a weekend toy
I know it probably is'nt the first time this has been done so any input would be appreciated, If I've messed up on this anywhere don't hold back let me know.
Old Apr 6, 2003 | 08:58 AM
rskrause's Avatar
Moderator
If you put sticky tires on it the drive shaft and transmission will be a problem. If not, you will be have a very fast car that spins the tires at will!
Sounds awesome. Good luck.
Rich Krause
Old Apr 6, 2003 | 09:19 AM
john35thss's Avatar
Thanks for the input Rich, but I was reading another post and you felt a cam smaller than what I'm using was too big. From reading some of your previous posts you had a similar combination. Will the charger flow enough air, I'm tring to build a car that will work with low boost so I don't need to intercool.
found my cam card its a comp cam 4873s/487s8 sr 114 0 +4
dur at .015 tappet 273/286
valve timing at .050 open close
int: 8 BTDC 48 ABDC
exh: 62 BBOC 6 ATOC
specs are for cam at 110 intake centerline
Agostino Racing installed cam at 111.5
Old Apr 6, 2003 | 11:41 AM
rskrause's Avatar
Moderator
int: 8 BTDC 48 ABDC
exh: 62 BBOC 6 ATOC
Not a very detailed reply, I know. It is too big for most people. But from the hardcore parts you selected, the indication that it's a weekend only car, I assumed you meant primarily racing. How's it going to be used? It will be a high rpm motor, I assume that's the reason for the SR cam?
Rich Krause
Old Apr 6, 2003 | 08:24 PM
john35thss's Avatar
The reason I used a solid rollor was I wanted to be sure I was getting the most from the grind.
The car will be driven on the street but won't see a lot of mileage ( 3000 tops per year). By high RPM I was shooting for 6500rpm max. The compression should be 8.7 to 1 (64cc chambers).
I hope I didn't put something to extreme to actually drive together.
Any ideas to improve
2QUIK6
Sep 17, 2016 02:31 PM
drt
Sep 27, 2015 04:39 PM
WPHIG2
Aug 27, 2015 06:37 AM
nd4spd200
Aug 21, 2015 09:30 AM
13qtr
Jul 19, 2015 05:30 PM
