Engine shake?
Old Apr 2, 2003 | 04:03 PM
blkn'silver94's Avatar
Engine shake?
How much does your engine shake?....i have new motor mounts and a complete overhaul on a Hot cam Kit, LT's, tuning everything basically except for Ported heads.....and it runs great...just at idle the engine has an intermitent shake. What is it?..thanks Tony
Old Apr 2, 2003 | 04:24 PM
MZK4252's Avatar
Could be misfire...sometimes it's not noticeable unless at lower RPM's. If you've got PolyU motor mounts they may cause a little more vibration as well.
Old Apr 3, 2003 | 12:23 AM
I think my idle is a bit too low..could that be it?....Its an A4 and the RPM's are marking like between 700-800..isn't that a little low for a cam?...
Old Apr 3, 2003 | 12:44 AM
MZK4252's Avatar
It depends on what they programmed it at. That does seem a little low for a cam though. I'd check with your tuner.
Old Apr 3, 2003 | 02:35 AM
Wild1's Avatar
Misfire could easily cause a shake... but I agree that those numbers are low for idle.
You mentioned that you installed the LT4 Hot Cam. On mine, I just re-adjusted the valves and noticed that the back side of a few rockers were "dished" that the pushrod created a groove or another pocket. This is causing an infrequent jolt at idle as the timing of that valve/cylinder is changing due to the angle of the pushrod to rocker arm geometry.
Could be programming (which should be done with a cam install). Could be misfire (probably ignition).
Could be mechanical (in my case it was bad rockers)
Good luck.
Old Apr 3, 2003 | 03:07 AM
gunna have to check it all tomarrow..thanks tony
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Bando
Oct 7, 2002 07:36 PM
Achilles97
Sep 13, 2002 10:49 AM
dmaastr
9
Jul 1, 2002 02:22 PM
