Will the rims off a 97 Z28 fit on a 94??
Old 12-31-2002, 12:57 AM
ReznorZ28's Avatar
I have a 94 camaro with salad shooters on it... I recently found some perfect chrome rims off a 97 Z28 and they are going to sell them to me for $300 + my salad shooters. I am just wondering if the rims would fit correctly?
Thanks in advance
ReznorZ28 is offline
Old 12-31-2002, 01:22 AM
Disciple
OctaneZ28's Avatar
In a word... YES
OctaneZ28 is offline
Old 12-31-2002, 01:53 AM
blksunshine's Avatar
Yes they do, you have to open up the rear wheels or they won't go on the hub. Just get a dremel and take some material off the inside. This is what i did
Later
Jose`
blksunshine is offline
Old 12-31-2002, 02:01 AM
chesee48's Avatar
Re: Will the rims off a 97 Z28 fit on a 94??
Thanks in advance
i gaurentee it! get rid of them shooters
chesee48 is offline
Old 12-31-2002, 12:56 PM
ReznorZ28's Avatar
I dont have a dremel... so that sucks.
Did anyone else have to do that? Or is there any other way to open up the rear wheels?
Later
Jose`
Old 12-31-2002, 01:02 PM
When you look at the inside of the wheel, there is a hole that the raised portion of the axle "hub" fits in. On the early 4th Gens, the rear hub diameter was approx 0.03" larger than the front hub. In later models, that was corrected. In order to fit the later model wheels on an earlier chassis, it is often necessary to remove the small ridge on the inside of the wheel's hub opening.
A Dremel makes it easier, but there is no reason you couldn't remove this small amount of soft metal with sandpaper or a file. You might want to do it on all 4 wheels, so that when you rotate the wheels and tires you don't forget to grind out the other 2 wheels.
Injuneer is offline
Old 12-31-2002, 01:06 PM
ReznorZ28's Avatar
So just look inside the rim and I will see the ridge that I need to sand down? Or is the ridge on the axle? Sorry for all the questions but I a little confused.
Old 12-31-2002, 03:30 PM
QUICK305's Avatar
Sand down the wheel, not the axle.
QUICK305 is offline
Old 01-01-2003, 12:12 PM
Try to put the wheels on and you will see the hole in the wheel is to small to go over the hub. I actually used an electric drill and bought a grinding stone to take some of the material off.
Old 01-03-2003, 03:53 AM
ReznorZ28's Avatar
Thanks for everyones help. I just bought the rims today and I filed down the ridge in the the rims(well in 2 of them at least) and they fit and look great!! I'll post pics when I can, but I dont think it would be too cool because my car still doesnt have a front end on it yet. Thanks again
Old 01-03-2003, 06:49 AM
Skull Leader's Avatar
Lightbulb
If I read this thread earlier, you could have borrowed my Dremel In fact I have a cordless Dremel that the battery runs out in 5 minutes, and corded, cheap but powerful Chicago brand or some crap.
Skull Leader is offline
Old 01-03-2003, 01:31 PM
ReznorZ28's Avatar
Thanks for the offer, but it only took me 5 mins to do it by hand with a file(per rim).... I didnt do a pretty job, as the ridge didnt look like it was evenly filed down all the way around, but the rims fit over the hub when I was done.
Old 01-03-2003, 03:18 PM
ReznorZ28's Avatar
well even though Im sure no one really cares and since you all have seen these rims before on other camaros, I am still going to post some pics ... even though I dont have a front end on the car I still get excited every time I look at the rims because Ive waited so long to get rid of them salad shooter! thanks again for everyones help! pics in sig
Kato
01-26-2015 09:21 PM
siguy
11-27-2014 10:07 AM
BigManJ
08-12-2002 02:47 PM
Wilson
07-21-2002 05:08 PM
Wilson
07-21-2002 04:58 PM
Quick Reply: Will the rims off a 97 Z28 fit on a 94??
