Door Cracks
Old 03-31-2015, 10:56 PM
birdblack's Avatar
Door Cracks
My '02 Formula has a crack in the right door panel along the top of the panel just under the window. Doing some internet browsing for a replacement panel shows me that this is a common problem for '97-02 Fbody door panel. As I have had no luck finding a replacement I was wondering if anyone has had any luck covering the plastic portion of the door panel with a vinyl wrap. Any suggestions or source for a replacement would be appreciated.
birdblack is offline
Old 04-01-2015, 09:33 AM
Re: Door Cracks
I just saw an article on repairing the door panel, without covering anything:
How to fix your already cracked door panels
Not a totally invisible repair, but looks decent.
Injuneer is offline
Old 04-11-2015, 06:48 AM
birdblack's Avatar
Re: Door Cracks
Has anyone ever tried adding some type of filler and then match the texture of the door panel?
Old 04-20-2015, 02:44 PM
ZeeS7o7's Avatar
Re: Door Cracks
Look into 6litereater, he might have made a replacement piece for this. Check out his site.....6litereater.com I think it is.
ZeeS7o7 is offline
Old 04-20-2015, 02:45 PM
ZeeS7o7's Avatar
Re: Door Cracks
pretty much all my friends with TA's have this problem.
ZeeS7o7 is offline
Old 04-20-2015, 04:24 PM
Re: Door Cracks
If you follow the procedure I linked, you will have a reinforced panel, and the "crack" may be virtually invisible, as the gray panel in the article. If you just fill the crack, without correcting the rub strip and pulling the sides of the crack together, it will just keep opening up.
If the crack seems too visible, as in the later black panel in the article, any sort of filler could be pressed in, and touched up. SEM makes some fairly good matching vinyl paint (Eastwood sells them under the Eastwood name as well), and whatever you fill it with could be painted with a very tiny brush.
Injuneer is offline
Aaront810
08-29-2020 09:34 PM
magman
04-15-2016 03:08 AM
David Dempsey
03-12-2016 12:42 AM
IndyZman
10-22-2015 02:17 PM
z28cam1993
09-09-2015 04:08 AM
Quick Reply: Door Cracks
